Anyone set up or have a Flow Meter on their main going to their house?
I would be interested in this as well. I think there was someone talking about a water valve cutoff switch, which was nice. But, I would like to be able to track how much water I am using as well.
I have the valve and mimolite to do the shutoff valve. I would also like to add the flow meter before the shutoff valve as added security of knowing there is a leak.
Or would just hooking up a arduino shield with an analog input wired to a flowmeter be the way to go?
There’s this:
But it obviously doesn’t help you today, tomorrow, or … a while from now.
Correct, I saw that. Just was seeing if anyone has done something like that already with different equipment.
I am looking at this http://www.instructables.com/id/Low-Cost-Water-Flow-Sensor-and-Ambient-Display/ with an Arduino shield.
Pardon me for bumping an older thread - but it’s still on point.
This looks like an extremely nice and flexible flow meter:
My limitation is the output signal. What would it take to:
- fully read it - so you get a relative gpm?
- just recognize that there is SOME flow - which is all I really care about - maybe at a set threshhold, with a potentiometer adjustment?
- recognize there is some flow for a long length of time and/or outside normal allowed times?
So I’m really limited / clueless as to how to hook that into smart things for any kind of meaningful input.
Thoughts?
Carl
