Don’t suppose you have one for a frient heat detector?
Is there a full list of channels that have drivers to them? I’m assuming this is the new way the community shares there own drivers. If so is the a list of channels.
Any chance you could give me an idiot’s guide to updating that driver. When I use the link I did before to enroll, it only gives me the option to uninstall the one I am using now?
I can’t tell how to install the driver you have identified in your latest post.
The driver it will be updated automatically in 12 hours max.
If you want update manually then can do wit CLI or if you uninstall the device from app and then remove the ols version driver from your hub, you can now install new version from the channel
It seems that although nobody has said anything since we reported in May that the libraries or the Hub did not manage more than 4 endpoints well, something has been fixed since it is the same driver that we tested in May, with the help of the documentation provided by @philh30, and it didn’t work.
Yes, I was having issues already. I haven’t reached the 50 Driver limit, but I’m having issues with the Hub reporting that it has no Memory. So having to add devices to a Second Hub.
Do you know if “Local” devices on one hub will communicate locally to devices on a Second Hub provided they are on the same vLAN ?
