Great new Xiaomi Aqara Sensor with illuminance detection
Xiaomi released a new sensor with light intensity detection:
It works great except I cannot make the intensity to be detected by ST.
Anyone has a custom DH out there?
Would be also interested in this!
Ive orderd two of them, hope someone makes a DH. god i love the xiaomi products, dirt cheap and good products.
I have this exact one and cannot add it to my ST hub. Is there a Device Handler for this one?
Are u adding it correctly? Mine is working except the luminosity part
Yes, I am adding it correctly…I think. I am not sure how I could add it incorrectly? I “Add a Thing” and it never shows up. I am assuming I need a DH. I tried the DH for the original Xiaomi human body sensor, but still nothing. Do you have a DH for the Aqara Human Body Sensor?
Have u clicked several times in the device button to put it in pair mode?
Have you found an answer to this?
My Aqara sensors were able to be added much easier than the older non-aqara Xiaomi sensors. With the add thing function on, hold the button for 5 seconds, wait 5, then press the button for 2 seconds. Might take a few goes but it does work. If it fails, the ‘catchall’ method will work.
I am using the aqara motion sensor DTH by bspranger/Xiaomi on Github - the light intensity is reported in percentage. I Haven’t got it working with the light controller app as it expects a lux reading…
I have just got 2 of these as I was interested in using the lux capability as well.
I have them paired and can see the light intensity being shown as a percentage.
Also when trying to add them to webCoRE they do not show up in the illumination sensor category.
I’ve also noticed in the bspranger DH that there is no capability for illumination so this is probably why.
Has anybody got these working as a lux sensor?
If so, how are they performing and what did you do to get them working.
Additional note. I see that light % only reports when there is motion. Is this correct?
TIA.
Correct. Only when motion triggers we get an updated lux value.
I have it working in WebCore…
When you say you have it working in webCoRE, is this for light measurement or motion?
light measurement…
I manage to add it as an illuminance sensor…
I am using this DH:
  • Xiaomi Aqara Motion Sensor with Lux
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • mods made (to bspranger’s fork) by inpier on 05/09/2017 to introduce lux reading. NOTE This only updates during a motion event as
  • the device does not appear to acccept the configureReporting command for illuminance.
  • Based on original DH by Eric Maycock 2015
  • modified 29/12/2016 a4refillpad
  • Added fingerprinting
  • Added heartbeat/lastcheckin for monitoring
  • Added battery and refresh
  • Motion background colours consistent with latest DH
  • Fixed max battery percentage to be 100%
  • Added Last update to main tile
  • Added last motion tile
  • Heartdeat icon plus improved localisation of date
  • removed non working tiles and changed layout and incorporated latest colours
  • added experimental health check as worked out by rolled54.Why
metadata {
definition (name: “Xiaomi Aqara Motion Sensor Lux”, namespace: “inpier”, author: “a4refillpad”) {
capability "Motion Sensor"
capability "Configuration"
capability "Battery"
capability "Sensor"
capability "Refresh"
capability "Health Check"
capability “Illuminance Measurement”
    attribute "lastCheckin", "String"
    attribute "lastMotion", "String"
    //attribute "illuminance", "String"
	fingerprint profileId: "0104", deviceId: "0104", inClusters: "0000, 0003, 0001, 0400, FFFF, 0019", outClusters: "0000, 0004, 0003, 0006, 0008, 0005, 0019", manufacturer: "LUMI", model: "lumi.sensor_motion.aq2", deviceJoinName: "Xiaomi Aqara Motion"
   //fingerprint profield: "0104", inClusters: "0000, 0400, 0406, FFFF", outClusters: "0000, 0019", manufacturer: "LUMI", model: "lumi.sensor_motion.aq2", deviceJoinName: "Xiaomi Aquara Motion"
    command "reset"
    command "Refresh"
simulator {
preferences {
	input "motionReset", "number", title: "Number of seconds after the last reported activity to report that motion is inactive (in seconds). \n\n(The device will always remain blind to motion for 60seconds following first detected motion. This value just clears the 'active' status after the number of seconds you set here but the device will still remain blind for 60seconds in normal operation.)", description: "", value:120, displayDuringSetup: false
tiles(scale: 2) {
	multiAttributeTile(name:"motion", type: "generic", width: 6, height: 4){
		tileAttribute ("device.motion", key: "PRIMARY_CONTROL") {
			attributeState "active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#00a0dc"
			attributeState "inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff"
        tileAttribute("device.lastCheckin", key: "SECONDARY_CONTROL") {
			attributeState("default", label:'Last Update: ${currentValue}',icon: "st.Health & Wellness.health9")
	valueTile("battery", "device.battery", decoration: "flat", inactiveLabel: false, width: 2, height: 2) {
		state "battery", label:'${currentValue}% battery', unit:""
    standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
        state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
    standardTile("configure", "device.configure", inactiveLabel: false, width: 2, height: 2, decoration: "flat") {
		state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
	standardTile("reset", "device.reset", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
		state "default", action:"reset", label: "Reset Motion"
	standardTile("icon", "device.refresh", inactiveLabel: false, decoration: "flat", width: 4, height: 1) {
        state "default", label:'Last Motion:', icon:"st.Entertainment.entertainment15"
    valueTile("lastmotion", "device.lastMotion", decoration: "flat", inactiveLabel: false, width: 4, height: 1) {
		state "default", label:'${currentValue}'
    standardTile("refresh", "command.refresh", inactiveLabel: false) {
		state "default", label:'refresh', action:"refresh.refresh", icon:"st.secondary.refresh-icon"
	valueTile("illuminance", "device.illuminance", width: 2, height: 2) {
		state "illuminance", label:'${currentValue}\nlux', unit:"lux"
	main(["motion"])
	details(["motion", "battery", "illuminance", "icon", "lastmotion", "reset", "refresh"])
def linkText = getLinkText(device)
log.debug “${linkText} Parsing: $description”
Map map = [:]
if (description?.startsWith('catchall:')) {
	map = parseCatchAllMessage(description)
else if (description?.startsWith('read attr -')) {
	map = parseReportAttributeMessage(description)
else if (description?.startsWith('illuminance')) {
		//getLumminanceResult(description)
        map = parseCustomMessage(description)
log.debug "${linkText} Parse returned: $map"
def result = map ? createEvent(map) : null
// send event for heartbeat
def now = new Date().format(“yyyy MMM dd EEE h:mm:ss a”, location.timeZone)
sendEvent(name: “lastCheckin”, value: now)
if (description?.startsWith('enroll request')) {
	List cmds = enrollResponse()
    log.debug "${linkText} enroll response: ${cmds}"
    result = cmds?.collect { new physicalgraph.device.HubAction(it) }
 log.debug "Parse returned $map"
   return result
private Map getLuminanceResult(rawValue) {
log.debug “Luminance rawValue = ${rawValue}”
def result = [
	value: '--',
	translatable: true,
	unit: 'lux'
result.value = rawValue as Integer
return result
/* Old method
private getLumminanceResult(String luxLevel) {
//log.debug luxLevel.substring(12)
def lux = luxLevel.substring(12)
log.debug "${linkText} Illuminance is  ${lux} lux"
sendEvent(name: "illuminance", value: "$lux")
//sendEvent(name: "Illuminance Measurement", value: "$lux")
return
private Map getBatteryResult(rawValue) {
//log.debug 'Battery’
//log.debug rawValue
def result = [
	value: '--'
def volts = rawValue / 1
def maxVolts = 100
if (volts > maxVolts) {
			volts = maxVolts
result.value = volts
result.descriptionText = "${linkText} battery was ${result.value}%"
return result
private Map parseCatchAllMessage(String description) {
Map resultMap = [:]
def cluster = zigbee.parse(description)
log.debug cluster
if (shouldProcessMessage(cluster)) {
	switch(cluster.clusterId) {
		case 0x0000:
		resultMap = getBatteryResult(cluster.data.get(30))
		break
case 0x0001:
// 0x07 - configure reporting
if (cluster.command != 0x07) {
resultMap = getBatteryResult(cluster.data.last())
break
		case 0x0400:
        	if (cluster.command == 0x07) { // Ignore Configure Reporting Response
            	if(cluster.data[0] == 0x00) {
					log.trace "Luminance Reporting Configured"
					sendEvent(name: "checkInterval", value: 60 * 12, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
				else {
					log.warn "Luminance REPORTING CONFIG FAILED- error code:${cluster.data[0]}"
			else {
        		log.debug "catchall : luminance" + cluster
            	resultMap = getLuminanceResult(cluster.data.last());
		break
case 0xFC02:
log.debug '${linkText}: ACCELERATION’
break
		case 0x0402:
		log.debug '${linkText}: TEMP'
			// temp is last 2 data values. reverse to swap endian
			String temp = cluster.data[-2..-1].reverse().collect { cluster.hex1(it) }.join()
			def value = getTemperature(temp)
			resultMap = getTemperatureResult(value)
			break
return resultMap
private boolean shouldProcessMessage(cluster) {
// 0x0B is default response indicating message got through
// 0x07 is bind message
boolean ignoredMessage = cluster.profileId != 0x0104 ||
cluster.command == 0x0B ||
cluster.command == 0x07 ||
(cluster.data.size() > 0 && cluster.data.first() == 0x3e)
return !ignoredMessage
def configure() {
// TODO : device watch?
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
log.debug "Confuguring Reporting and Bindings."
def configCmds = []
configCmds += zigbee.batteryConfig()
//configCmds += zigbee.configureReporting(0x406,0x0000, 0x18, 30, 600, null) // motion // confirmed
// Data type is not 0x20 = 0x8D invalid data type Unsigned 8-bit integer
configCmds += zigbee.configureReporting(0x400,0x0000, 0x21, 0, 600, 0x20) // Set luminance reporting times?? maybe  Not working
return refresh() + configCmds
def enrollResponse() {
log.debug “${linkText}: Enrolling device into the IAS Zone”
// Enrolling device into the IAS Zone
"raw 0x500 {01 23 00 00 00}", “delay 200”,
“send 0x${device.deviceNetworkId} 1 1”
def refresh() {
log.debug “Refreshing Values”
def refreshCmds = []
refreshCmds +=zigbee.readAttribute(0x0001, 0x0020) // Read battery?
//refreshCmds += zigbee.readAttribute(0x0402, 0x0000) // Read temp?
refreshCmds += zigbee.readAttribute(0x0400, 0x0000) // Read luminance?
//refreshCmds += zigbee.readAttribute(0x0406, 0x0000) // Read motion?
//log.debug refreshCmds
return refreshCmds + enrollResponse()
private Map parseReportAttributeMessage(String description) {
Map descMap = (description - “read attr - “).split(”,”).inject([:]) { map, param ->
def nameAndValue = param.split(":")
map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
//log.debug “Desc Map: $descMap”
Map resultMap = [:]
def now = new Date().format("yyyy MMM dd EEE h:mm:ss a", location.timeZone)
if (descMap.cluster == “0000” && descMap.attrId == “0005”) {
log.info “Cluster 0000 and AttrID 0005”
if (descMap.cluster == “0001” && descMap.attrId == “0020”) {
resultMap = getBatteryResult(Integer.parseInt(descMap.value, 16))
// Luminance
else if (descMap.cluster == “0400” ) { //&& descMap.attrId == “0020”) {
log.error "Luminance Response " + description
//result << getBatteryResult(Integer.parseInt(descMap.value, 16))
else if (descMap.cluster == "0406" && descMap.attrId == "0000") {
	def value = descMap.value.endsWith("01") ? "active" : "inactive"
    sendEvent(name: "lastMotion", value: now)
    if (settings.motionReset == null || settings.motionReset == "" ) settings.motionReset = 120
    if (value == "active") runIn(settings.motionReset, stopMotion)
	resultMap = getMotionResult(value)
return resultMap
private Map parseCustomMessage(String description) {
Map resultMap = [:]
if (description?.startsWith('illuminance: ')) {
// log.info “value: " + description.split(”: ")[1]
//log.warn "proc: " + value
	//def value = zigbee.lux( description.split(": ")[1] as Integer ) //zigbee.parseHAIlluminanceValue(description, "illuminance: ", getTemperatureScale())
	def value = description.split(": ")[1]
    resultMap = getLuminanceResult(value)
return resultMap
private Map parseIasMessage(String description) {
List parsedMsg = description.split(’ ')
String msgCode = parsedMsg[2]
Map resultMap = [:]
switch(msgCode) {
    case '0x0020': // Closed/No Motion/Dry
    	resultMap = getMotionResult('inactive')
        break
    case '0x0021': // Open/Motion/Wet
    	resultMap = getMotionResult('active')
        break
    case '0x0022': // Tamper Alarm
    	log.debug '${linkText}: motion with tamper alarm'
        break
    case '0x0023': // Battery Alarm
        break
    case '0x0024': // Supervision Report
    	log.debug '${linkText}: no motion with tamper alarm'
        break
    case '0x0025': // Restore Report
        break
    case '0x0026': // Trouble/Failure
    	log.debug '${linkText}: motion with failure alarm'
        break
    case '0x0028': // Test Mode
        break
return resultMap
private Map getMotionResult(value) {
//log.debug "${linkText}: motion"
String descriptionText = value == ‘active’ ? “${linkText} detected motion” : "${linkText} motion has stopped"
def commands = [
value: value,
descriptionText: descriptionText
return commands
private byte[] reverseArray(byte[] array) {
byte tmp;
tmp = array[1];
array[1] = array[0];
array[0] = tmp;
return array
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
def stopMotion() {
sendEvent(name:“motion”, value:“inactive”)
def reset() {
def installed() {
// Device wakes up every 1 hour, this interval allows us to miss one wakeup notification before marking offline
log.debug "${linkText}: Configured health checkInterval when installed()"
sendEvent(name: “checkInterval”, value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID])
def updated() {
// Device wakes up every 1 hours, this interval allows us to miss one wakeup notification before marking offline
log.debug "${linkText}: Configured health checkInterval when updated()"
Thanks for this but do you have the link where you got it from as it would be easier to copy in in.
Sorry but don’t…
Looks like this code from @ArstenA:
https://github.com/bspranger/Xiaomi/blob/master/devicetypes/a4refillpad/xiaomi-aqara-motion-sensor.src/xiaomi-aqara-motion-sensor.groovy
This is the one that i already have.
There is no illuminence capability in this one. That I can see anyway.
Hi @Sergio_Ferreira
Is there anyway you can post the cost in the same way that @jymbob posted his?
While I really appreciate your help, I’m afraid I cannot copy and paste the code with the way you have posted it.
Thanks.
are you sure you’ve got the latest version? I’ve got illuminance here, and I’m pretty sure that’s the DTH I’m using…
If you look at the code you have posted, there is no capability for Illuminance. (Under line 37).
If you look at the code that @Sergio_Ferreira posted you will see that there is and also there are additional fingerprint profileId’s in lines 43,44.
I can copy those in to the existing code easy enough but it is going through all the code to find the differences that is the problem.
Someone obviously wrote the code for the new DH but I just need to know who so that I can hopefully find it on github.
