Has anyone tried adding a battery holder to the Visonic devices? Something similar to adding the battery holder to arrival sensor? I tried one over the weekend without reading any voltage requirement and it did not work.
I don’t see why it does not work. Visonic battery is 3V which is the same as the battery holder (1.5v x 2)
I did not personally try it. Did you see the little light turn on when you put in battery into the holder?
