Virtual temperature sensor (for V3 app)
Looking to see if anyone has a device handler for a virtual temperature sensor (one that can receive a value) that works properly with the new app.
I am using code for the Classic app that worked very well. I have another app that takes a temperature value from a thermostat and assigns it to the virtual temperature sensor.
The assignment is working fine in the V3 app, but three things bother me: (1) it has no temperature icon, (2) it has no units when viewed on the home page, and (3) its units are deg C when I pull up the device detail.
Thanks in advance!
I did knock up one a while back that might be suitable. It certainly works in the new app fine but whether it does the exact job you need is another matter.
Thanks, looks like it will work @orangebucket . Since I have another app manipulating the temperature, I don’t have a need to do it through the device. Can this capability be taken away? And is there possibility for a decimal point (showing up without)? Thanks!
