Vimar Zigbee Roller Shutter doesn't work
Hi everyone. I’m new and i bought the hub a few days ago, so i’m trying to learn.
My smarthome is based on Vimar View Wirless system and every light switch works well with zigbee connectivity, but i’ve got 3 roller shutters and with zigbee they don’t work. I select “curtains” in type of device in IDE and in the app the roller shutter take the commands, but after they don’t respond and send me error message. On alexa app i see the device, but i can’t controll. how can i resolve it? Thanks and sorry for my BAD english!
Hey Luca,
Did you find a DTH for the specific zigbee rollers? just selecting a generic dth does not mean it will work properly with the system.
I don’t know how to do that. I just try to change the “type” and i select “zigbee curtains” on the IDE. Where can i find the DTH?
You need to search. What make and model is your device?
This is my device. The light switchs work, this one not.
Yeah pretty sure you won’t be able to get this to work. You really should research what is compatible before buying.
It works :wink: Just change DH
Yes it works but you need to use ZigBee Window Shade
Since I understand you’re italian, why don’t you join our Facebook Group for ST Italian users? You’ll find many users with experience on Italian devices (Vimar in particular)
Hi Luca,
Could you share what kind of DH did you use to solve the problem?
Grazie
Hi Alberto.
I used a custom dh, just copy that
  • Copyright 2019 SmartThings
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
import groovy.json.JsonOutput
import physicalgraph.zigbee.zcl.DataType
metadata {
definition(name: “ZigBee Window Shade 2”, namespace: “smartthings”, author: “SmartThings”, ocfDeviceType: “oic.d.blind”, mnmn: “SmartThings”, vid: “generic-shade”) {
capability “Actuator”
capability “Configuration”
capability “Refresh”
capability “Window Shade”
capability “Window Shade Level”
capability “Window Shade Preset”
capability “Health Check”
capability “Switch Level”
	command "pause"
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0102", outClusters: "0019", model: "E2B0-KR000Z0-HA", deviceJoinName: "eZEX Window Treatment" // SY-IoT201-BD //SOMFY Blind Controller/eZEX
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0102", outClusters: "000A", manufacturer: "Feibit Co.Ltd", model: "FTB56-ZT218AK1.6", deviceJoinName: "Wistar Window Treatment" //Wistar Curtain Motor(CMJ)
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0008, 0102", outClusters: "000A", manufacturer: "Feibit Co.Ltd", model: "FTB56-ZT218AK1.8", deviceJoinName: "Wistar Window Treatment" //Wistar Curtain Motor(CMJ)
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0102", outClusters: "0003", manufacturer: "REXENSE", model: "KG0001", deviceJoinName: "Window Treatment" //Smart Curtain Motor(BCM300D)
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0102", outClusters: "0003", manufacturer: "REXENSE", model: "DY0010", deviceJoinName: "Window Treatment" //Smart Curtain Motor(DT82TV)
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0102", outClusters: "0003", manufacturer: "SOMFY", model: "Glydea Ultra Curtain", deviceJoinName: "Somfy Window Treatment" //Somfy Glydea Ultra
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0020, 0102", outClusters: "0003", manufacturer: "SOMFY", model: "Sonesse 30 WF Roller", deviceJoinName: "Somfy Window Treatment" // Somfy Sonesse 30 Zigbee LI-ION Pack
	fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0020, 0102", outClusters: "0003", manufacturer: "SOMFY", model: "Sonesse 40 Roller", deviceJoinName: "Somfy Window Treatment" // Somfy Sonesse 40
preferences {
	input "preset", "number", title: "Preset position", description: "Set the window shade preset position", defaultValue: 50, range: "1..100", required: false, displayDuringSetup: false
tiles(scale: 2) {
	multiAttributeTile(name:"windowShade", type: "lighting", width: 6, height: 4) {
		tileAttribute("device.windowShade", key: "PRIMARY_CONTROL") {
			attributeState "open", label: 'Open', action: "close", icon: "http://www.ezex.co.kr/img/st/window_open.png", backgroundColor: "#00A0DC", nextState: "closing"
			attributeState "closed", label: 'Closed', action: "open", icon: "http://www.ezex.co.kr/img/st/window_close.png", backgroundColor: "#ffffff", nextState: "opening"
			attributeState "partially open", label: 'Partially open', action: "close", icon: "http://www.ezex.co.kr/img/st/window_open.png", backgroundColor: "#d45614", nextState: "closing"
			attributeState "opening", label: 'Opening', action: "pause", icon: "http://www.ezex.co.kr/img/st/window_open.png", backgroundColor: "#00A0DC", nextState: "partially open"
			attributeState "closing", label: 'Closing', action: "pause", icon: "http://www.ezex.co.kr/img/st/window_close.png", backgroundColor: "#ffffff", nextState: "partially open"
		tileAttribute ("device.windowShadeLevel", key: "SLIDER_CONTROL") {
			attributeState "shadeLevel", action:"setShadeLevel"
	standardTile("contPause", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
		state "pause", label:"", icon:'st.sonos.pause-btn', action:'pause', backgroundColor:"#cccccc"
	standardTile("presetPosition", "device.presetPosition", width: 2, height: 2, decoration: "flat") {
		state "default", label: "Preset", action:"presetPosition", icon:"st.Home.home2"
	standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 1) {
		state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
	main "windowShade"
	details(["windowShade", "contPause", "presetPosition", "refresh"])
private getCLUSTER_WINDOW_COVERING() { 0x0102 }
private getCOMMAND_OPEN() { 0x00 }
private getCOMMAND_CLOSE() { 0x01 }
private getCOMMAND_PAUSE() { 0x02 }
private getCOMMAND_GOTO_LIFT_PERCENTAGE() { 0x05 }
private getATTRIBUTE_POSITION_LIFT() { 0x0008 }
private getATTRIBUTE_CURRENT_LEVEL() { 0x0000 }
private getCOMMAND_MOVE_LEVEL_ONOFF() { 0x04 }
private List collectAttributes(Map descMap) {
List descMaps = new ArrayList()
descMaps.add(descMap)
if (descMap.additionalAttrs) {
	descMaps.addAll(descMap.additionalAttrs)
return descMaps
// Parse incoming device messages to generate events
log.debug “description:- ${description}”
if (device.currentValue("shadeLevel") == null && device.currentValue("level") != null) {
	sendEvent(name: "shadeLevel", value: device.currentValue("level"), unit: "%")
if (description?.startsWith("read attr -")) {
	Map descMap = zigbee.parseDescriptionAsMap(description)
	if (isBindingTableMessage(description)) {
		parseBindingTableMessage(description)
	} else if (supportsLiftPercentage() && descMap?.clusterInt == CLUSTER_WINDOW_COVERING && descMap.value) {
		log.debug "attr: ${descMap?.attrInt}, value: ${descMap?.value}, descValue: ${Integer.parseInt(descMap.value, 16)}, ${device.getDataValue("model")}"
		List<Map> descMaps = collectAttributes(descMap)
		def liftmap = descMaps.find { it.attrInt == ATTRIBUTE_POSITION_LIFT }
		if (liftmap && liftmap.value) {
			def newLevel = 100 - zigbee.convertHexToInt(liftmap.value)
			levelEventHandler(newLevel)
	} else if (!supportsLiftPercentage() && descMap?.clusterInt == zigbee.LEVEL_CONTROL_CLUSTER && descMap.value) {
		def valueInt = Math.round((zigbee.convertHexToInt(descMap.value)))
		levelEventHandler(valueInt)
def getLastLevel() {
device.currentState(“shadeLevel”) ? device.currentValue(“shadeLevel”) : device.currentValue(“level”) // Try shadeLevel, if not use level and pass to logic below
def levelEventHandler(currentLevel) {
log.debug “levelEventHandle - currentLevel: ${currentLevel} lastLevel: ${lastLevel}”
if ((lastLevel == "undefined" || currentLevel == lastLevel) && state.invalidSameLevelEvent) { //Ignore invalid reports
	log.debug "Ignore invalid reports"
} else {
	state.invalidSameLevelEvent = true
	sendEvent(name: "shadeLevel", value: currentLevel, unit: "%")
	sendEvent(name: "level", value: currentLevel, unit: "%", displayed: false)
	if (currentLevel == 0 || currentLevel == 100) {
		sendEvent(name: "windowShade", value: currentLevel == 0 ? "closed" : "open")
	} else {
		if (lastLevel < currentLevel) {
			sendEvent([name:"windowShade", value: "opening"])
		} else if (lastLevel > currentLevel) {
			sendEvent([name:"windowShade", value: "closing"])
		runIn(1, "updateFinalState", [overwrite:true])
def updateFinalState() {
def level = device.currentValue(“shadeLevel”)
log.debug “updateFinalState: ${level}”
if (level > 0 && level < 100) {
	sendEvent(name: "windowShade", value: "partially open")
def supportsLiftPercentage() {
device.getDataValue(“manufacturer”) != “Feibit Co.Ltd”
def close() {
log.info “close()”
zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_CLOSE)
def open() {
log.info “open()”
zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_OPEN)
def setLevel(value, rate = null) {
log.info “setLevel($value)”
setShadeLevel(value)
def setShadeLevel(value) {
log.info “setShadeLevel($value)”
Integer level = Math.max(Math.min(value as Integer, 100), 0)
def cmd
if (isSomfy() && Math.abs(level - lastLevel) <= GLYDEA_MOVE_THRESHOLD) {
	state.invalidSameLevelEvent = false
if (supportsLiftPercentage()) {
	level = 100 - level
	cmd = zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_GOTO_LIFT_PERCENTAGE, zigbee.convertToHexString(level, 2))
} else {
	cmd = zigbee.command(zigbee.LEVEL_CONTROL_CLUSTER, COMMAND_MOVE_LEVEL_ONOFF, zigbee.convertToHexString(Math.round(level), 2))
return cmd
def pause() {
log.info “pause()”
def currentShadeStatus = device.currentValue(“windowShade”)
if (currentShadeStatus == "open" || currentShadeStatus == "closed") {
	sendEvent(name: "windowShade", value: currentShadeStatus)
} else {
	zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_PAUSE)
def presetPosition() {
setShadeLevel(preset ?: 50)
  • PING is used by Device-Watch in attempt to reach the Device
    def ping() {
    return refresh()
def refresh() {
log.info “refresh()”
def cmds
	cmds = zigbee.readAttribute(CLUSTER_WINDOW_COVERING, ATTRIBUTE_POSITION_LIFT)
} else {
	cmds = zigbee.readAttribute(zigbee.LEVEL_CONTROL_CLUSTER, ATTRIBUTE_CURRENT_LEVEL)
return cmds
def installed() {
log.debug “installed”
sendEvent(name: "supportedWindowShadeCommands", value: JsonOutput.toJson(["open", "close", "pause"]), displayed: false)
def configure() {
def cmds
log.info "configure()"
// Device-Watch allows 2 check-in misses from device + ping (plus 2 min lag time)
sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
log.debug "Configuring Reporting and Bindings."
	cmds = zigbee.configureReporting(CLUSTER_WINDOW_COVERING, ATTRIBUTE_POSITION_LIFT, DataType.UINT8, 0, 600, null)
} else {
	cmds = zigbee.levelConfig()
return refresh() + cmds
private def parseBindingTableMessage(description) {
Integer groupAddr = getGroupAddrFromBindingTable(description)
if (groupAddr) {
List cmds = addHubToGroup(groupAddr)
cmds?.collect { new physicalgraph.device.HubAction(it) }
private Integer getGroupAddrFromBindingTable(description) {
log.info “Parsing binding table - ‘$description’”
def btr = zigbee.parseBindingTableResponse(description)
def groupEntry = btr?.table_entries?.find { it.dstAddrMode == 1 }
log.info "Found ${groupEntry}"
!groupEntry?.dstAddr ?: Integer.parseInt(groupEntry.dstAddr, 16)
private List addHubToGroup(Integer groupAddr) {
[“st cmd 0x0000 0x01 ${CLUSTER_GROUPS} 0x00 {${zigbee.swapEndianHex(zigbee.convertToHexString(groupAddr,4))} 00}”, “delay 200”]
private List readDeviceBindingTable() {
[“zdo mgmt-bind 0x${device.deviceNetworkId} 0”, “delay 200”]
def shouldInvertLiftPercentage() {
return isSomfy()
def isSomfy() {
device.getDataValue(“manufacturer”) == “SOMFY”
private getGLYDEA_MOVE_THRESHOLD() { 3 }
Hello
I try to use your custom DH for my roller shutter but I get error when pasting it in code area any chance to send it to me: jjkalia@gmail.com
