Using multiple Sonos PLAY:1s
Is there a way to use more than one play 1 with. Smart app. So far any way I try to use more than one when you choose which Sonos it only let’s you choose one. I have 3 of them in my home, and in some situations for a custom message would like all 3 of them to be used.
Not sure I understand the question. I only have one Sonos Play 1 but Couldn’t you just configure each one separately by installing the same app three times ?
Example
My App: SayHello1 : When {presence sensor 1 detected} -> Sonos 1 Say "Hello Person 1"
My App: SayHello2 : When {presence sensor 1 detected} -> Sonos 2 Say "Hello Person 1"
My App: SayHello3 : When {presence sensor 1 detected} -> Sonos 3 Say “Hello Person 1”
Or are you saying that each time you try to set up an app only one of your sonos play 1’s is listed. That sounds like the other two were not paired with your ST correctly. Or there is a bug ?
The point I mean is that I shouldn’t have to create 3 separate smart apps that is doing the exact same thing for each one. It would be better if I could make one smart app that included all 3 Sonos. Much in the same way that you can choose multiple lights to turn on or off based on triggers, etc.
