All,
. I have a 3 conductor AC line that runs from my house to patio. And I have several motion sensor floodlights (think Driveway lights). I have the motion sensor outputs connected together in a “wired-Or” fashion. So if any motion sensor trips, all the lights turn on. ie: if a motion sensor trips, it doesn’t matter which one, all the lights turn on. Works great! See diagram.
. Then the red wire got cut. Instead of digging and burrowing under a cement walkway to replace the conductor with a new wire/conductor, I’d like an easier way. Like maybe use the “Mirror” function.
. So the red wire, on either side of the break, will have 120V or 0V, regardless of which motion sensor tripped.
. The mirror feature ALMOST sounds like a solution. But from my reading, the mirroring is One Way. I need Two Way mirroring. The motion sensors on either side of the break should be able to energize & de-energize the red wire on either side (both sides) of the break.
. I hope I explained that clearly.
. Any ideas? TIA
. Fastb
