I am looking to do a couple of automation based on devices being on. E.g turn on my workstation when my laptop is on. Or don’t run goodnight if the TV is on. Are there any USB switch devices that i could pair with smartthings? So if there is power to he device, smartthings recognises it as on?
I don’t know how many devices you are looking to monitor… but I use a power monitor on my TV that e.g. runs a rule to not turn off the heating at night if the TV is still on (power level is above a threshold).
Buy a Samsung TV, that way the smartthings hub knows its exact state and you can control it using alexa. I know thats not very helpful but I couldn’t resist
Sonoff do a smart USB switch but I dont think that’s what your actually looking for. Although you could use that as a monitored switch. But there would be a delay because you’ve said your usb’s aren’t powered when off, so any device plugged in would have to wake-up and connect to your hub before they could be used for anything
If your devices are connected to your hub/alexa device you could use virtual devices to run automations. E.g. if alexa sees your TV on it will turn on a virtual device and that in turn can be included in your current “dont run goodnight if TV is on” automation
