Hello.
Has anyone got to use a zwave EU usb dongle (868 mhz) with a US smartthings hub (908 mhz)?
My story is that i already have lots of fibaro eu devices, also a homecenter2, and now i bought a ST hub, but is it US version.
Is there a way to add a usb dongle or anything else like a gateway, hub, or whatever, in order to be able to add 868mhz devices to my us st hub?
Ok. Thanks.
And how about an arduino or raspberry gateway?
I mean, have an arduino or raspberry with a zwave dongle and ethernet, and use that as a gateway.
To smartthings? No, you would have to run some software on the RPi (like HomeAssistant) to manage your z wave devices and then connect that to ST. You’re better off just buying a ST EU hub As you will constantly being getting unintended info for you. Your hub will always be designated as being in the US when it isn’t. I don;t think it’s intended to work they way you’r trying to make it work. If you’re in the EU, buy an EU hub. If you’re in the US, buy a US hub.
actually i´m in argentina, southamerica. it’s easier to buy here the us version, but if it will be a pita then i better sell it and try to buy an european one.
if there was a driver to link smartthings hub with fibaro homecenter then my issue would be solved, but i think it’s not a good option.
Thanks for your answers ryan.
Best regards!
