UPDATE: Recent SmartThings User Experience & Platform Performance
I haven’t noticed a single one here.
It is the brains of the huge majority of your system. The hub does very little (v2) or no (V1) local processing.
Then you have picked the wrong system. There’s little to no hope of seeing fully local processing from the ST hub, regardless of version.
Custom rules take MORE server power, not less. Only Smart Lighting commands are executed locally by the V2 hub.
ST won’t exist without the Server Cluster. You don’t want ST if you want to run local. I doubt that ability will ever be there.
Cloud based systems (not only ST) rely on a solid Internet connection (reliability and speed) and a reliable and high performance cloud based system. This is true of Office360, ST, or any other cloud based system.
I would have no issues with ST staying cloud based if two things happened. The greatly improved performance and latency issues on the cloud side and gave me redundancy on the hub side. On the hub I’d like to run most of the time on the home Internet connection, but switch to a mobile (Verizon, etc) connect if the home connection was down. Add those things and rock solid reliability and it could stay cloud based for me.
@ndavis82
What are you using for your proximity? My windows phone is sporadic at best, none of our android phones are registering coming or going since this started. We left the house on Sat. it armed the system, we came home it didn’t disarm. Yesterday I left it didn’t arm but when I came home it disarmed. Friday it did neither.
I’m having the same issues now. Everything else has stabilized.
I fixed all my rules Saturday. I have a trigger that fires at 0625 every weekday. It fired correctly yesterday but nothing today. I went into IDE and nothing was scheduled. Even the previous times were gone. Checked my rule on my phone and the event trigger was missing AGAIN. Only actions appeared. Rebuilt it and I guess we’ll see what tomorrow has in store for ST.
3 posts were merged into an existing topic: New scheduler (Codename: Ticker) being rolled out
So at midnight MST it finally stabilized and so far today the hub is OK. I’ll continue to keep an eye on the bugger
[quote=“jstraughn, post:378, topic:42547”]
I have a trigger that fires at 0625 every weekday. It fired correctly yesterday but nothing today. I went into IDE and nothing was scheduled. Even the previous times were gone. Checked my rule on my phone and the event trigger was missing AGAIN. Only actions appeared. [/quote]
I have the opposite problem. Conditional triggers where only the trigger remains; conditions and actions are MIA, with no way of gaining menu access to fix them – have to delete and recreate. Strangely, when CTs are in this state, the missing conditions and triggers are still visible in the IDE (but do nothing when triggered).
I am seeing the same 43 second failure on several IP devices since the new scheduler went into production
4 posts were merged into an existing topic: New scheduler (Codename: Ticker) being rolled out
Good to know… thank you!
As of right now all my stuff are working the way they should be. I never did go in and change things as in removing and adding back. Never changed the name of things. I just suffered through and its all working just fine.
Now with that said, this is only day 2 for everything working since the crash. Hope it stays this way.
Everything for me ran fine last night and this morning. Did a bunch of tests to make sure the scheduler fired as advertised, not one glitch. Very minor delay a few times, maybe a second or 3 before it seemed to update, but that might just be the IDE. My complex lighting rules in my office, sometimes have three scheduled tasks at a time, worked great. My wife didn’t yell at me for the alarm going off either, so bonus!
A post was merged into an existing topic: New scheduler (Codename: Ticker) being rolled out
One of the main things i had going on was a GE dimmer became unresponsive. Testing today shows that it’s back, but when i turn it on and off with the app, my open/close sensors go nuts. They open for a few seconds then close right back. And it’s never the same ones. Just hiccups i guess.
everything is working for me, even proximity sensor routines EXCEPT SHM, i can’t disarm or arm, it just spins.
Anyone else having problems with contact sensors switching stats (closed to open) randomly without the window/door being opened?
I either have to manually open/close the sensor or force reset it from the IDE with a custom device handler
What kind of contact sensors do you have?
Does it happen in this scenario…
You’re in one of the rooms in the rooms tab. There agree are multiple devices on the room. You tap on a bulb or switch to turn it on and at the same time either one or multiple contact sensors open? I’Is it usually the one right next to the device you tapped on?
