@Jon_Hope please share your code. I’d be interested to see if I can get this integrated.
Sure, I will send you a private message when I’m in front of my computer and can easily cut and paste.
Just wondering if you got any further with this? Or for that matter if anyone else has?
I’ve got an EU v2 and its reporting Volts at 89:
Current States
energy: 0.04 kWh
power: 1124.4 W
voltage: 89.034 V
current: 25.095 A
powerCost: 2.38586691672 £/day
lastReset: 2017/04/25 06:44:54
statsMode: Today
costOfEnergy: 0.00327117 £
energyToday: 2.486 kWh
costOfEnergyToday: 0.21978726 £
energy24Hours: 13.650 kWh
costOfEnergy24Hours: 1.20679650 £
energy7Days: 45.328 kWh
costOfEnergy7Days: 4.00744848 £
energyMonth: 45.221 kWh
costOfEnergyMonth: 3.99798861 £
energyYear: 45.221 kWh
costOfEnergyYear: 3.99798861 £
energyLifetime: 45.328 kWh
costOfEnergyLifetime: 4.00744848 £
dispPower: 1124.4 W
dispPowerCost: £2.39 per day
dispCurrent: 25.1 A
dispVoltage: 89.0 V
dispEnergy: 0.04 kWh
dispCostOfEnergy: £0.00
dispEnergyPeriod: 2.49 kWh
dispCostOfEnergyPeriod: £0.22
Are you all still using the DTH linked by @daleajones above.
Cheers
Ive got the mihome (Energinie) hub and whole house monitor. There is a smart app to hook that into smartthings.
Hub will also give you other connected device and swicth capability…
and here is the monitor
for smart app…
Hi Jon
I have a Wattson and Energyhive hub so would be grateful if you could share tyhe code you developed. I want to link my Wattson to Smartthings.
Hi Jon, please can you share your Wattson code. I have one and want to link it to Smartthings.
Hi, sorry I have not logged in for a while.
here is my code, though sadly im only here because my integration stopped working.
- Wattson Energy Monitor
- Copyright 2017 Jon Hope
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
preferences {
input “token”, “text”, title: “Access Token”, required: true
metadata {
definition (name: “Wattson Energy Monitor v2”, namespace: “Jon Hope”, author: “Jon_Hope”) {
capability "Power Meter"
capability "Polling"
capability "Health Check"
capability "Refresh"
capability "Sensor"
capability “Actuator”
attribute "curMonthName", "string"
// simulator metadata
simulator {
for (int i = 0; i <= 100; i += 10) {
status “power ${i} Wh”: new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
tiles (scale: 2) {
valueTile(“power”, “device.power”, width:6, height:4)
state “device.power”,
label: ‘${currentValue}W’,
icon: “https://cdn4.iconfinder.com/data/icons/environmental-and-ecology/48/environmentalsvg-02-512.png”,
backgroundColors:[
[value: 1, color: “#fff000”],
[value: 200, color: “#fff000”],
[value: 300, color: “#42db13”],
[value: 400, color: “#C3C300”],
[value: 600, color: “#ffce00”],
[value: 800, color: “#FFFB14”],
[value: 1000, color: “#FFA500”],
[value: 1500, color: “#ff7400”],
[value: 2000, color: “#ff5a00”],
[value: 3000, color: “#ff0000”]
//graph tile goes here
//last reading tile
valueTile("readingUpdated", "device.readingUpdated", width: 4, height: 2, decoration: "flat") {
state "default", label:'Last Reading:\n${currentValue}'
//refresh tile
standardTile(
"refresh",
"device.refresh",
inactiveLabel: false,
decoration: "flat",
width: 2,
height: 2) {
state("default",
action:"polling.poll",
icon:"st.secondary.refresh")
// end of tiles
//end of metadata
// handle commands
def poll() {
log.debug "Executing ‘poll’"
getReading()
// Get the sensor reading
private getReading() {
def today = new java.util.Date()
def strDateFormat = “MMMM”;
def sdf = new java.text.SimpleDateFormat(strDateFormat);
def curMonthName = sdf.format(today)
def curMonth = device.currentValue(‘monthName’)
def readingClosure = {
response ->
log.debug "result: $response.data"
log.debug "last reading time: $response.data.last_reading_time"
log.debug "reading: $response.data.reading"
log.debug "Current Month: $curMonthName"
sendEvent(name: “power”, value: response.data.reading)
def tf = new java.text.SimpleDateFormat(“MMM d, yyyy - h:mm:ss a”)
tf.setTimeZone(TimeZone.getTimeZone(“Europe/London”))
def readingUpdated = "${tf.format(response.data.last_reading_time)}"
log.debug "Last Updated: $readingUpdated"
sendEvent(name: “readingUpdated”, value: readingUpdated)
sendEvent(name: “curMonthName”, value: curMonth)
def params = [
uri: “http://www.energyhive.com”,
path: “/mobile_proxy/getInstant”,
query: [“token”: token],
contentType: ‘application/json’
httpGet(params, readingClosure)
I’m currently pretty close to getting this to work with energyhive:
So just to update you I managed to get version 3 of the efergy device handler working with energyhive. I had to comment out lines 1052 and 528 from the code as written, because I think energyhive’s api is subtly different has has no support for the tarrif rate. Once those lines are gone it seems fine.
Good luck!
Hey, do you know where I can buy the Aeon HEM you’ve mentioned? I’ve just set myself up on InfluxDB/Grafana using your guide and would love to pipe in the power consumption data for my whole home
