Hi,
I can’t find any smart smoke alarms and heat alarms that are mains wire-able ? Therefore none seem compatible with UK building regs requiring a hardwired system ?
Seems mad that Scotland seems to have approved wireless systems for HMOs but England/UK regs about 20 years behind the technology!
And the manufacturer has been providing edge Drivers for some of their devices, but I don’t know if they’ve done one for that specific device. You should ask in their thread:
Our Z-Smoke does not support a hardwired alarm loops between devices. They do, however, support 230V mains wiring to power the device and wireless associations which will synchronise the alarm outputs.
We do not have a heat alarm which triggers the sirens based on heat, the Z-Smokes do report temperature, but only as a sensor (and thereby trigger interconnected alarms).
I use a Frient heat detector which is battery powered, appreciate you needed hard wired but thought i would put it out there
Also ST Home monitor does not allow for heat detector integration, there are reliable ways around the issue with a virtual smoke alarm but again just putting out there incase interested
