TZ66D integration with ST HUb
Hello,
Has anyone experienced pairing a TKB Home TZ66D in Wall Switch and Dimmer with a SmartThings Hub? I have been trying to do that for a while. I also read somewhere that it is not compatible. However, this is a Z-Wave certified device and so is ST Hub and I assume they should talk to each other.
Am I missing something here?
Thanks,
Abdul
The issue you’re going to have it it’s dual relay, which ST doesn’t natively support. But the community has made multi relay devices work if you are up for a little custom device type.
Thank you for your post Matt,
I happened to have read this. At this point I was looking for an answer or a step-by-step guide to be able to pair the TZ66D with SmartThings.
Interestingly in the same thread that you refer, Daniel wrote
So I was wondering if there was a way to pair.
Thanks,
Abdul
I don’t have the TZ66D so I can’t say for sure. I’d recommend posting in the other thread trying to get the assistance of someone who’s done it.
