I am aware that oficially the TKB TZ66D isn’t supported.
But in any event, I want to give it a try from my amateur developer side to see where I can get…
Where would I start? I was told by TKB the following:
For the TZ66D wall switch, the right paddle is not seen in the system. Because there is sigle relay in TZ66D.
The right paddle only act as a controller. You can control other z-wave devices by association via right paddle.
Any ideas on how to see thru a console or something what’s going on behind the scenes?
as I said, I’m not even a programmer… I have done a few things here and there but nothing too serious… but I’m not afraid of trying…
Sure thing, it does pair, but only the left paddle (local) works, the right paddle, which would be the one that would start/stop scenes or other actions is the one that’s missing…
Well if it pairs, you could develop a device handler. Or perhaps use a similar device from the IDE. I am still learning, so I would not be the best person for this. However, if others here are interested (typically they see a use for it) then they generally speak up.
You do realize that ST doesn;t work with Scenes right?
@danielccm please let us know if you have questions and if you’re successful, I may want to pick up a few of these switches if they can be made to work.
Open SmartThings IDE in your web browser and log into your account.
Click on the “My Device Types” section in the navigation bar (or open the SmartDevices page).
On the “'s Device Types” page, click on the “+ New SmartDevice” button on the right.
On the “New SmartDevice” page, fill out the mandatory “Name” field. It does not matter what you type in the name field since it will be overwritten in the next step anyway. Click the blue “Create” button at the bottom of the page. An IDE editor window containing device handler template should now open.
Copy the source code you want to start with – either by clicking the from"device type examples" button on the upper right-hand side of the page or by copy&paste from code in GitHub. Either way, make sure you completely overwrite contents of the editor window with the source code copied.
Click the blue “Save” button above the editor window. Click the “Publish” button next to it and select “For Me”. You have now self-published your smart device handler.
Installing a SmartDevice
In the SmartThings IDE, click on the “My Devices” section (or open the Device List page).
On the “Device List” page, click on the “+ New Device” button on the right.
On the “Create Device” page, enter device name in the mandatory “Name” field. You can use any name here.
Optionally, enter device label in the “Label” field. This is the actual label that will displayed in the SmartThings mobile app.
Fill in the mandatory “Device Network Id” filed. You can enter any string or number here, since it will be overwritten by the device handler anyway.
In the mandatory “Type” field, select (from the drop-down list) the name of your device TYPE from step 1-2 .
In the mandatory “Version” field, select “Self-Published” from the drop-down list.
In the “Location” field, select location where you want to install new device.
In the “Hub” filed, select the name of your SmartThings hub.
Refresh Device List in SmartThings Mobile App. Open the SmartThings app on your mobile device, go to the Dashboard and log out of your SmartThings account. Exit and restart the SmartThings mobile app.
Log back in into your SmartThings account. Your new device should now appear on the “Things” page.
Reviving this old thread just in case anyone found a way to make the THBHOME TZ66D double light switch compatible…
I’ve used this time to become a little more familiar with the IDE… But still don’t know how to create a new device… Any chance you could help me? Thanks!
You can get to the app on your mobile by going to “Marketplace > SmartApps > More > Multi-Channel Control”
I am also keen on finding a 2 and a 3/4 gang single Z-Wave enabled switch that will work with the SmartThings Hub. I am also keen to find out if the “TZ66D” will work with the official Multi-Channel Control smartapp as I am keen to get one or something similar.
There is another post on the Multi-Channel Control smart app here and here.
EDIT: Dispite appearing to be a double switch, I have found out that the TZ66D only has one switched output, the other switch is to control other Z-Wave enabled devices.
The MCO Z-WAVE Glass Touch Panel Switch 2 Button has two switched outputs and may work with the official Multi-Channel Control smartapp, but I can’t say for sure. It is also rather expensive costing around £70-£80.
I like the idea of the other zwave enabled devices being controlled by the TZ66D… Would we be able to come up with a Device Handler to use that ability? I’m no programmer, but I could be a good guinea pig! lol!
Hello all, Did anyone get the TZ66D working with the ST hub?
I have a TZ66D wall switch installed, and can get the switched paddle to connect as a generic Z-Wave switch, but the RH Paddle can’t seem to connect or show up in ST… I can only control one of the two lights!
Would love to get this working, as the functionality would be very useful for me!
