OK, so I’m a little bummed out cause I just acquired a lightly used Aeon Labs Minimote and apparently there seems to be two versions of this remote out in the market. The version I have may have been designed for a verizon system (some are sold with the title verizon skin on ebay) where the top buttons have the numbers 1, 2, 3, 4 and JOIN button under the slider.
Questions:
Has anyone with this numbered version gotten their remote to work with the button controller app? I hear that the other version out there WITHOUT the numbered buttons and with the LEARN button seems to work fine with the app.
Should I come to a conclusion for now that it is not currently compatible/supported by SmartThings?
My experience on this “numbered/JOIN” remote:
With my “numbered” version, when I pair the remote using the JOIN button the hub recognizes the remote as a “Z-Wave Remote” but when I tap to configure and name the remote “A new device was added, but was not the correct type. Continue to search…” then in the things menu I see a blue circle with the number 1 and the words “Not Yet Configured”. It seems like it’s actually paired with the hub since it is now seen as a “thing” however it will not be recognized as a button from the button controller app. ugh…
Thanks for any support or experience you may have on these remotes!
