I have a generic Tuya smart switch, the manual control only works as a switch. To convert the control from a switch to a button I have to intervene with Tuya but when I go to disconnect it and reconnect it to Smarthings, the option is reset.
When you Remove the device from the Tuya or SmartLife app you should get 2 options.
- Remove
- Remove and Clear Data
Chose the 1st option [Remove] and it should retain your changes. I have done this many times with no issues.
Hi Paolo Oliver thanks for the reply.
I looked for the option to remove without deleting the data but I didn’t find this option.
Could you guide me?
In the Tuya or SmartLife apps; open device tile > press pencil or 3 dots in upper right corner > scroll to bottom of page > select Remove Device > select Remove (1st choice).
I made a mistake and removed the device and erased the data.
Just removing the device worked thanks so much for your help
Glad it worked for you.
