I have a virtual switch that is turned on via “Set Responses” in the ST Home Monitor when a security/smoke/leak event is triggered. This is working great.
However, is there any way to turn off this switch when any or all of these events are dismissed?
Right, I actually did create a virtual alarm with the vEdge Creator, the problem is that within the Home Monitor options you have to set an “Alert Duration” thereby shutting off the virtual switch automatically rather than leaving it on until I actually dismiss the alert. I’m trying to keep the virtual switch on until I dismiss the alert.
Don’t set a duration in STHM and set the duration individually for each alarm device.
I can do that using settings for each alarm. If you don’t have that option you could do it with a routine.
Yeah, still not exactly what I’m looking for. Was hoping to have the switch automatically get turned off after the alarm was dismissed by SHM. Thanks for the input.
No, I’m talking about the built-in ST Home Monitor. I’m using Android, so I can’t say where it is exactly for you, but it’s under the “SmartThings Home Monitor” on Android.
