Im playing round with virtual switches and SmartThings Home Monitor. I have an automation that once Home Monitor is turned on and it picks up motion it will set a siren off. But I need to give my self some grace time to deactivate it with Alexa and I cant see a “wait” function.
How are people doing this?
RBoy
#2
It has a “delay” for entry and exit actions giving your time to disarm or exit the house before it triggers things. It can be used in conjunction with STHM dashboard using virtual switches.
I was actually looking at your app, looks quite cool. I just want to get a proof of concept running before I start buying things though.
I don’t actually have a siren, I’m using a virtual switch to trigger an Alexa skill, so I’m trying to find a way to make that hard to turn off and as I said set a delay on running the automation.
I can also see that you do Audio Notifications like fire alarms does that mean I can use your app to play an Alarm though an Alexa speaker that cant be turned off without a code or some kind of imput in the Smartthings app?
Also notifications in your app, I’m in AU does the SMS function work?
RBoy
#6
You can has Audio notifications with any device that supports audio playback. At this time Alexa doesn’t support it, only voice notifications through Echo Speaks. However you can use a Bose or Sonos to play audio files and speak messages.
