I’ve got one these nice GE z-wave lighting module dimmers (12718). When I first set it up I somewhere remember an option listed whether I’d like the switch to turn on instantly or “dim on”. I originally selected the “dim on” feature but now realize it’s a bit annoying because it takes forever to turn on. Does anyone know how I can just have the module turn my lamp on at 100% all the time?
I do not have this exact device but other GE products… in the App - go to the device -> select the “gear” top right (settings) -> I get “dim Rate” to select AND Dim transition fro On/Off commands “yes” or “no” option.
Ok, so I’m not crazy! That option used to exist in the iOS app but now I don’t see it. Device options are:
-Give Your Device a Name
-Update Icon
-LED Indicator
-Replace
-Remove
Any ideas why I’m not seeing the “Dim rate” option anymore???
If you are still looking to adjust the ramp rate on the GE dimmer module, you might try customizing the step size/duration parameters using a custom device handler, which will allow you to speed up the on/off dimming transitions. There are a few custom device handlers floating around, but this one worked well for me for both the dimmer module (GE 12718) and in-wall dimmer switch (GE 12724):
FWIW, I settled on a step size of ‘2’ (2%) and a step duration of ‘3’ (3ms) for a smooth, speedy transition.
Once you have set the custom ramp rate parameters using the custom device handler, you can switch back to the stock device handler to restore local control (on a v2 hub).
Just a note that you can now use the Z wave tweaker device type handler with any Z wave device to expose all of its parameters and make it easy to change them. Once you have them configured, just switch back to your everyday device type handler.
