rey_rios
(Rey Rios)
June 1, 2016, 7:59pm
1
I am trying to the following. Not sure if there is an app or how to do it in ST. I can do this with IFTTT but I cannot tell IFTTT do not fire if none is at the house.
Is there a way I can read the temperature from outside (using SmartWeather Tile 2.0) and make that the trigger to turn on the fan (or really any switch)?
dalec
(Dale C)
June 1, 2016, 10:18pm
2
Sure, this is pretty basic home automation. I am assume you are referring to this device handler right?
This is pretty much the same thing as the Smart Weather station tile app but with more fields, nicer look using the mult-itile attribute and added a few more fields that i felt were missing.
This was made for my account, i was showing my friend and he liked it so i am sharing it with you guys.
Here are some screenshots:
[image]
[image]
Here is the link for download (add to your device handlers)
Weather Station Tile 2.0
I have added options under settings to change units.
Enjoy
UPDATE:
Here is how it looks on android from users below:
[image]
To install follow these steps:
There are 2 ways: 1) copy and paste , 2) update from repo
This is easy but be careful when you copy the code because cut-and-paste breaks the ° symbol in the source and you end up with a q…
I just tested it using Virtual Thermostat smartapp and it worked fine for your application.
rey_rios
(Rey Rios)
June 1, 2016, 10:28pm
3
Thanks. I will try the Virtual Thermostat app.
