Turn off after 5 minutes even if door let open
Hi,
Currently my rule looks like: turn on the light if motion or door open, turn off after a few minutes.
However the door it’s let open something and so the light stay own for hours.
Will any smartapps turn off everything on after a few minutes?
It’s suppose to turn it off. I’d open a support case.
I would (If you haven’t) Set the rule back up and if it still does not turn it off then open a ticket. It should be turning it off
May be you can set a rule to turn the light ON when door opens and turn it off “x” mins after its closed. That way the light remains ON as long as the door is open.
