Trying to install webCoRE. Tried numerous times. Not sure if it is working in Canada.
you did the following:
logged into https://account.smartthings.com
installed the 4 webcore smartapps
enabled OAuth on the webcore smartapp
published all 4 smartapps
in the ST app, go to the Automations section, click on the + in the upper right, choose Add Routine, click on the Discover tab and scroll to the bottom to find it in the custom smartapps
now time for my usual note: webcore will cease when ST stops support for groovy on the platform so it would only be a short term use at this point.
Thanks that worked. I didn’t go to discover
