Try mHome's AI agent to create powerful automation through chat
Hi folks!
I’m excited to introduce my new automation agent, mhome.ai. It generates automations effortlessly, purely using English or any other language you prefer. Check the gif example.
It already connects to SmartThings! Support most widely used capabilities.
The platform support super powerful automation logics. You can ask the assistant to trigger on different combinations of conditions, continuous state, count occurrence in a time window, run action conditionally, wait a duration for certain condition then to resume, … It also does simple calculations, like tell you the temperature difference between two rooms. And more…
Give it a try and explore! (Fair warning: it might fail occasionally, but we’re working hard to improve it)
Visit mhome.ai for more info.
While there is a waitlist, I’m enrolling users quickly, usually within a day.
Thank you!
chrome_mG4sADvfAe
chrome_ycf9qsWlb8
Looks great but there’s a waitlist I’m unable to test the system
I’m already on the waiting list to be able to test it.
It seems incredible to me!
Once I authenticate it launches a new window and doesnt finish the process.
I got it to work however it’s still a bit limited. I would still want a editor and not just the chatbot to generate routine as it’s a bit annoying to refine. It would be easier to just edit.
hmm, could you provide more error details. Is that for user login? or auth for smatthings connection?
you mean a UI editor or a script editor
I am having the same problem.
I see this in SmartThings, but no devices show up in mhome.
When I do authentication in SharpTools I see the following and it works, I don’t get this far with mhome
Thanks! Seems it happens when redirected from ST app. I pushed a fix. Please try again
So, the connection is now completing but I don’t appear to import any devices. I have over 200 devices at this SmartThings location that could get imported.
yes, It’s error getting devices. quite weird. Could you disconnect and connect again?
When I went to delete the SmartThings integration as you suggested this evening, I found that my SmartThings devices finally showed up in mHome. I was able to write a simple automation with no errors, and it worked as expected.
