This is my first attempt to install a new GE 12729 dimmer switch; my smart home currently consists of a very robust SmartThings hub and 2 plug in switches!
I purchased the dimmer switch to install in our kitchen; the circuit powers two overhead pendant lights, one over the sink and one over the island. Seems like a very simple swap with one single switch. The switch is in a 3 gang box, but each of the 3 switches is on a separate circuit, as one switch works the lights (the one I’m attempting to replace), one works the disposal and the other the dishwasher.
I removed the cover and turned off the 3 breakers (Note: I write the breaker number on the inside/back of the switch plate for easy reference…try it!)… I confirmed each of the circuits were off, and I pulled out the switch in question. It had 3 sets of wires coming into the box for that switch, 1 set for line and 2 for load (the 2 light fixtures)… seemed pretty straightforward. The switch ONLY had the black/hot wires connected to it, which made sense to me.
I removed the switch from the hot wires, separated them, then turned that one breaker back on the confirm the line wire; using one of those “tone” sensors, I identified the one that was live; the other two were “load”…turned breaker back off.
I then turned my attention to the Neutral and Grounds… the 3 white neutral wires were all connected together with a wire nut and neatly tucked in the back of the box (not connected to the switch)… and ALL the ground wires for all 3 circuits in the box were connected with a wire nut…(none of the 3 switches were connected to the ground bundle)
So, here’s what I did… 1) I got a piece of bare copper wire from my garage to pigtail off the ground; connected it; 2) I pulled the circuit neutral wires out, and attached the jumper wire (included with the switch) to the neutral bundle, then 3) I wired up the circuit this way:
Put the ground into the ground slot in the switch; put the neutral in the neutral slot on the switch; put the line wire in the line slot, and put the two load wires in those two spots…checked connections, then turned on the breaker… I toggled the switch and NOTHING…
I then tried to connect the switch to my SmartThings hub and I could not find it. I swapped out a bulb in one of the fixtures…Nothing… I double checked my connections…Nothing…
I turned off breaker, disassembled the whole thing, re-installed the original switch, and LIGHTS! Dang It!!!
An interesting side note: This circuit also powers a few wall receptacles, and an old hard wired security system in our home (we no longer use it)… But, anytime I turn off that breaker, and turn it back on, the house siren sounds when it is powered back on (this is due to the backup battery being dead…)… BUT, when the GE Dimmer was wired up to the circuit, and I powered on the breaker, there was no siren… I don’t know what that means…
so…long story to say, I have a nice smart dimmer sitting on my study desk, and I don’t know what I did wrong; any input would be greatly appreciated…
Some of my 3 way switches were (lack of better words) daisy chained I believe on the load.
Just be safe and if you are note sure turn the power off and call an electrician. Sorry I don’t have any better advice.
Good luck.
