Hello everyone,
I am currently powering PoE cameras located inside the house using a PoE midspan in between my cameras and non-PoE ethernet switch. This permits me to cycle on/off the midspan power using standard zwave switch so the cameras turn off when someone is home and on again when everyone leaves. I need to replace my switch soon and I was looking at the ubiquiti line of PoE switches. I would like to cut the midspan out completely (since the switch can supply its own power), while retaining the ability to cut power from certain cameras using a virtual smartthings switch. I came across this post from the ubiquity community forum that suggests an ability to trigger a PoE port On/Off remotely using SSH, telnet, or a .bat file. I am a bit out of my depth, but I am hoping someone with greater knowledge can spoon feed me an idea to work out a way to trigger PoE ports on a switch via smartthings?
