I have an Aqara G4 Doorbell, Aqara M2 hub, and some Aqara door contact sensors with the sensors bridged to ST. The G4 doorbell has an indoor chime I would like to trigger by ST. I have it set to alert if a door opens that has an Aqara door contact sensor, but I have some other door sensors in ST from Konnected that I would like to use to trigger the Aqara chime. Doesn’t look like an Aqara capability for IFTTT, so I’m failing to see a way to connect these in this manner to have my ST contact sensors trigger the Aqara chime. I can change those to Aqara sensors but wanted to see if there was a way to avoid that.
It requires buying an additional device, but you can get an aqara smart plug that would be visible in both the aqara app and the SmartThings app and use that as a proxy. But that may not give you enough use cases. ![]()
That could work for my use. I can just set it to turn on/off if any ST/non-Aqara contact sensor opens/closes. Thanks!
@JDRoberts Amazon had a plug here overnight and I had it set up and working to solve this for me in less than 5 min! Thanks!
Can anyone share their experience with the Aqara G4 doorbell? It’s on the compatible list, but it seems to connect via cloud account integration. The functionality available in the ST app is interesting.
Thanks. Can you tell us more about the functionality available in the ST app? Is it possible to watch the camera broadcast at any time? Is it possible to create automations that start recording video? And is two-way audio communication available?
See above and here Matter enabled smart lock - #109 by Andrew_Bartlett
Yes watch live in Smartthings, Aqara App or Alexa App or on Echo Show or Firestick.
Records all movement.
Yes, turn on microphone.
