Greetings. I am new to Smart Things and just installed my hub last night. I have this Trane thermostat and didn’t see it on the list of thermostats to add. I know that it is Z Wave and wondering if anyone could point me in the right direction on how to add it. Thanks in advance.
If it is not on the list, I would look through the IDE here. You will need to create a device under my device types menu. Ignore all but the Name and descipttion,
Then if you look on the right side of the screen you will see a section called Device Type Samples. Click there and you will see many different devices that the community has built. You can use these to possibly build your device into the ecosystem.
It is also possible that someone has done this already, or that a default type will work with your Thermostat. Have you tried to pair it with the ST network? And if so, what has happened?
@David_Leiva it doesn’t need to be in that list for it to work.
Have you tried to pair it? I would write into support if you have an issue with it.
