I’ve searched the community extensively and have some ideas on a good thermostat for my Trane system (9 year old 19.5i system), but I want the community feedback also.
My current Trane thermostat has a built in humidity sensor…and uses it to adjust humidity (remove humidity) by running the AC. I’d like to retain that functionality.
Is there a compatible thermostat that can do this? I could probably buy a separate humidity sensor and devise some codes/app functionality to mimic this, but I’d like to keep it as simple as possible.
A few options I’ve seen discussed:
Ecobee3 (should work fine…but too much $$)
CT100 (I think it may work, if I add the code to reveal the humidity sensor reading…but not sure)
Zen (I don’t think Zen has a humidity sensor)
Honeywell ZWSTAT (not sure if this has a humidity sensor)
Others?
Mike
