So, it sounds like platform maintenance was a ploy by the platform maintenance guys to ensure job security!
@slagle
Iām too tired to find the right thread for this, but there have been a couple of reports in the forums of people who were losing connection with zigbee devices (or more accurately appeared to be losing connection with zigbee devices) who are also getting fail messages when running a Z wave repair.
Since those are actually two separate independent local networks with two separate controllers, I donāt think Itās a local network issue. Maybe cloud synchronization.
The only thing working in my house right now is the phillips stuffā¦
Back to the dark ages here.
Iām unplugging until everything gets sorted out.
You could try just rebooting the hub. Power off (including removing the batteries) for 15 minutes, then power on and see if that improves things. Canāt hurt and might resynch.
true. I did unplug, but only for a minute⦠Iāll try that now!
Ok, So I unplugged the hub and waited a while⦠plugged it back in, got the green lightā¦
and well, everything is working now.
I had to cycle some lights and some contact sensors, but they are all up and running.
Iām sure it wonāt last, but Iām going to hope it does.
Thanks⦠i wasnāt leaving it unplugged for long enough.
So my sunset automation that has been failing did run tonight. And still shows blank for the next schedule.
My run at 7 AM automation does have a pending schedule. Weāll see if it runs in the morning, and more interestingly, whether the sunset automation runs tomorrow night.
This is what.pisses off. I reported this problem days ago right after the maintenance . Support just got back to wanting to.help me run a repair
It is one thing if they acknowledged the issue and gave usefull info. Totally.another to pontificate ⦠it as if they are in Another universe.
I think to report an issue in this thread now, one should have pulled the plug on their hub for 15 minutes, plugged back in, and then had a timed event fail. I say this only because I am observing people having success now doing this step in other threads.
Detail:
- @slagle post about reboot
- I believe the 15 minute sleep rebuilds zigbee network (not sure about zwave). Iām not sure what this would have to do with timing at allā¦
- I donāt know if the folks having success also have to also āresetā apps that use times too, or if the hub sleep/reboot fixes it.
- My personal experience is that I only had two timing issues, and all I did was reset those two items (one was a reset SmartApp, and one was my sunrise routine) and they have worked fine since. I have not had to reboot my hub at all, in fact itās been up since I installed it, not been off once.
- Probably unrelated, but the Android app is behaving horribly (only since the platform update), and I wonder if itās horrible behavior is wreaking havoc in the backend.
Hello,
I have been having issues too, I reset my events and now they seem to be going off on schedule but I now have another problem. When a new routine is triggered it is not overriding the old routine. So last night I had night time fighting with day time and it short cycled my heating all night⦠Has anyone else seen this issue as well?
Not sure what you mean by āoverridingā. Routines are allowed to fire anytime you tell them to, so you can accidentally and easily short cycle anything. You should probably start another thread and paste in it your settings there so people can help. This thread is about things not firing. Also contact support telling them you are short cycling your heat, but note that they are warning people that they are still slow to respond right now.
Iām having issues with some routines working and some not⦠these are VERY simple, built in time based events, so nothing more than lights turning on and to a certain level at certain times. Some work, some do not⦠I donāt get it.
How do I create a ticket for this so I too can put this issue in and hopefully get a little more attention on the subject?
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=smartthings%20support
Also, please reboot your hub as described in my post a couple above and then check on your timed events after that.
I completely agree. @slagle, itās definitely worth it to post this.
I was not having any trouble, and the times/scheduled events were not bothering me until yesterday. I had nothing working at all. But I believe my issues fell into the category of what others were referring to as poltergeist in the system.
I had tried rebooting my system a couple of times, to no avail. I would unplug the hub and leave it that way for about a minute. Being a network guy, that always works for modems and routers.
With advice from @jdroberts, I unplugged the hub for about 15 minutes. When I brought it back online things were very close to normal. I did have to cycle a few of my lights, but not everything.
My scheduled routines did for on time this morning. My lights were also responding to sensors, as programmed.
Not due how long this will hold, but it did fix it for now.
@slagle, what are the chances that a software reboot could be added to the app. I would recommend that it be a hard reboot of the system, if the hardware is capable of it.
Donāt get too happy, itās a matter of time before youāre back in ādark agesā. I have been rebooting my hub several times since Saturday. It works for couple of hours before things get out of sorts again. I have problems with runin () timers and not only with Smart Lighting, as well as problems using zigbee/zwave integration.
Not getting happy as it is still frustrating⦠But Iām always glad to find a fix, even if itās temporary.
While a temporary, repeatable fix, is never ideal it is almost always better than having a completely down system.
I guess after 20 years naval aviation where we were just glad the planes came home with our seat of the pants repairs conditioned me to just be glad things are working for the moment.
I woke up this morning and checked my ST logs.
Good Night (issued from Minimote at 11:15Pm) - successful
Good Night (automatic) - failed last night at 11:30Pmā¦no entry in log.
Good Morning (automatic) was successful at 6:00Am!!!
Things appear normal now at 6:30Am.
check the scheduler as I outlined instructions above⦠my guess is good night will be scheduled in the past and continue to fail⦠Good morning running is not an indication that it will not continue to failā¦
