Time based events failing?
I haven’t seen a bias towards routines or other schedules. They both seem fairly unstable at this point.
Some members also complained about poltergeist infested lights which turn on/off by itself.
My lights triggered by luminance sensor (darkness) are also not consistently triggering since the upgrade.
Yes, only one light out of two configured to light after motion lit. What was stranger, another light next to it went on. Seems to too odd to be a bug or malfunction. If I wrote the software for this I would say I was full of it. Hard to believe.
We should try to keep this to timing related events. I think everyone agrees that this is the one consistent issue here. Poltergeists suck, but I don’t know if they relate to time. Also I saw luminance above, that is definitely not a time issue.
Also having time scheduled events failing – lights that do not turn off. Multiple occasions over the past week. Different lights too, so its not just one switch or one command. Lights wont turn on at sunset, nor will be turn off at a scheduled time.
I’ve had both sunrise/sunset and manually set time-based events affected recently. In particular my Smart Lighting app was not working. Out of curiosity I opened the app, checked my setttings (all of which were fine), and saved the app settings again. Since then these events appear to be working again. I’m not certain if re-saving the app settings caused it to begin working again, but it appears to be a good possibility.
My sun state functioned just fine as did my timed lighting. The only thing that didn’t work was my Routine…which ironically was time triggered.
We should spin another thread for poltergeist light issues…
Add me to the list. None of my lights turn on this morning that are time-based :confused:. Put in a support ticket
For the failed time based event, can you try varying the time by a minute or so, click done and check if it triggers? It did help me to open the offending routine and click “done” again.
I still had issues last night with lights failing to turn off at specified times. Had to push the button on the routine and then they turned off.
I tried off setting everything by two minutes and saving will see if that works morning :grinning:
For mysterious light turning on/offs, there is another thread for sharing your experiences
I have a Goodnight routine that is set to run at 1:00 AM every night. All it does is turn off all the lights and locks the door. This has worked perfectly for weeks but has failed to run for past 3 times. The only way I know it hasn’t run is there is nothing in the Messages that indicates it ran. Normally the software places a message that it is running Goodnight and verifies that everything is set properly.
Good Night failed - not in log.
Good Morning failed - not in log.
My Minimote is programmed for Good Morning & Good Night (button 2).
Minimote started routines work.
My Tasker App scheduled tasks are running late.
ST V1
Nexus 5 Stock V6.0 MM
Many MM users having time issues with v6.
https://code.google.com/p/android/issues/detail?can=2&start=0&num=100&q=Time&colspec=ID%20Type%20Status%20Owner%20Summary%20Stars&groupby=&sort=&id=189789
I see the same problems with smart lights automations.
I have one which ran fine prior to the most recent platform update.
All it does is turn a light on at sunset. It doesn’t run. I’ve tried changing it and resaving. Creating it all together new. Changing the name of the automation. It doesn’t run.
Not only that, it’s not scheduled to run. The schedule is completely blank. This is different than my other automations.
The other parameters are there and set correctly, but it never gets scheduled.
Yahoo! My sunset (based on luminance) finally worked today and the popcorn effect was the shortest ever. Sorry if this is off topic but this thread was really created as a result of failed triggers from last update in my opinion anyway.
Ouch! I was about to raise the victory flag after a full day of success since changing/re-saving all time triggers and taking the hub fully offline/online.
Welllll…
It would seem that this little problem has found its way down here to Alabama…
My routines fired on time.
But nothing is responding… things are turning on and off at random. The app says they are on, but they are off. The app says they are off, but they are on…
hmmm…
