I used the access token to integrate my smart things devices into home assistant. the issue being that while the app reports the thermostats humidity the api does not. I cannot set automation in home assistant without the humidity.
Would this for sure be an api issue or an issue with the home assistant integration.
How would I go about testing the api in a diffrent senario to see if the humidity appears. Other devices have no issue showing humidity in home assistant.
