The RUELS API cannot be created. What is the problem?
    "name": "autoAirConditioner",
    "actions": [{
        "if":{
            "and":[
                    "changes":{
                        "equals":{
                            "left":{
                                "device":{
                                    "devices":[
                                        ID
                                    "component": "main",
                                    "capability": "presenceSensor",
                                    "attribute": "presence"
                            "right":{
                                "string": "present"
                    "greaterThan":{
                        "left": {
                            "location": {
                                "attribute": "Temperature"
                        "right":{
                            "integer": 25
            "then":[{
                "command": {
                    "devices": [
                        ID
                    "commands":[{
                        "capability": "airConditionerMode",
                        "command": "setAirConditionerMode",
                        "arguments": [
                            "aIComfort"
AxiosError: Request failed with status code 422: {"requestId":"8977413607307905002","error":{"code":"ConstraintViolationError","message":"The request is malformed.","details":[{"code":"BodyMalformedError","target":"Unknown target","message":"Malformed body on line
1:526","details":[]}]}}
Code: ERR_BAD_REQUEST
I’m getting this error, I don’t know what’s wrong. Where do I need to edit to create it?
It doesn’t help that it seems to see the JSON as one line. You could count 526 characters in perhaps, or …
I think it might be the arguments at the end. The sample in the API reference is very dubious and has been for years. I’d try:
{ "string": "aIComfort" }
No, you shouldn’t use string instead of array. Doing so causes other errors to occur.
I didn’t mean instead of the array, I meant:
"arguments": [
Problem solved. Thank you for your kind reply👍
