A problem occurred while creating rules. Please let me know what is the problem!
 "name": "every7AM. turn on light",
 "actions": [
     "every": {
       "specific": {
         "daysOfWeek": [
           "Sun",
           "Mon",
           "Tue",
           "Wed",
           "Thu",
           "Fri",
           "Sat"
         "reference": "Midnight",
         "offset": {
           "value": {
             "integer": 420,
             "type": "integer"
           "unit": "Minute"
       "actions": [
           "command": {
             "devices": [
               "<deviceID>"
             "commands": [
                 "component": "main",
                 "capability": "switch",
                 "command": "on"
           "type": "command"
           "command": {
             "devices": [
               "<deviceID>"
             "commands": [
                 "command": "on"
                 "capability": "airConditionerMode",
                 "command": "setAirConditionerMode",
                 "arguments": [
                     "string": "cool",
                     "type": "string"
                 "capability": "thermostatCoolingSetpoint",
                 "command": "setCoolingSetpoint",
                 "arguments": [
                     "integer": 23,
                     "type": "integer"
           "type": "command"
       "sequence": {
         "actions": "Parallel"
     "type": "every"
when i tried to create rule, the error message below is output.
    "error": {
        "code": "ConstraintViolationError",
        "message": "The request is malformed.",
        "details": [
                "code": "BodyMalformedError",
                "target": "type",
                "message": "Unrecognized field \"type\" (class v20190122.internal.st.behaviors.Operand), not marked as ignorable",
                "details": []
I know the approximate cause, but I don’t know what part to fix specifically. help please!
I found out why!
rules api doesn’t support “type”.
so i removed all “type” elements, then i receive “200 OK”! :slight_smile:
