I have several SMT1000’s some networked, some just serial spread accross multiple locations I would like to monitor and help develop. Is OP still active?
If this is still being worked on I would like to test also.
lost hope…
Did this die out?
Please tell me there’s something still here. This is a fantastic idea that I literally have been researching today after putting in a UPS for my internet hardware.
Even if there’s just instructions.
This isn’t the same - but I’ve recently got a simple switch working using a pi and NUT for my APC 1500 smart.
followed these instructions and barring a few issues it now works.
It would be great to see UPS stats live via a smartapp.
@SteveWhite is this dead or are you still thinking about resuming this? Could you share what you have so far with the community?
Thanks!!
I tried to reach out to Steve White, but decided to roll my own when I didn’t hear back. The setup is about the same: A raspberry pi monitoring the UPS over UBS. This is a little different than HandyHarley’s project in that the RPI presents a UPnP service on the LAN, which the smartthings Service Manager can discover.
Awesome man! Start a new thread and showcase your work! You deserve it!
this look exactly like what i need. ive got a pi running nut and can pull out ups status, but i have no idea how to implemet your code. do you have any instructions at all?
thanks again.
I updated the README for the python service you run on your pi. I should have mentioned, it assumes
upsc myups 2> /dev/null produces sensible output. You then install the service and DHT into your ST IDE. Lastly, you can discover your device through the service app.
thanks - yes I get a good output from upsc myups 2> /dev/null.
i’ll have a play and see what happens!
hi, ive had a look at this but somehow still having issues.
i’m running the service and getting the following output:
Traceback (most recent call last):
File “main.py”, line 4, in <module>
from lib.upnp_http_server import UPNPHTTPServer, get_network_interface_ip_address
File “/home/pi/upsmonitor/lib/upnp_http_server.py”, line 1, in <module>
from http.server import BaseHTTPRequestHandler, HTTPServer
ImportError: No module named http.server
only just getting into linux so its a learning curve. am i missing something?
Lets move the installation discussion to How to install · Issue #1 · brianegge/upnp-ups-service · GitHub
ok thanks.
So your fork is a fork of a fork with 20+ commits ahead. It might be time to just create a new repo and put a reference back to the forks and this thread in the readme. Also start a new thread like @Benji said. Think that would make the most sense at this point.
Any chance of ever seeing this as a direct driver via Telnet connection?
Trying to run this on unRaid 6.6. I have nut running no worries. Do you have a Docker Hub account? Might make process easier than cloning from git
I’d be interested but for all my APC UPS’s already network connected, short of just monitoring I’d also would like tot power cycle the UPS when needed from ST
