TBK Dual Dimmer--setting associations?
Welcome!
This used to be difficult to set up, but now is pretty straightforward thanks to some excellent work by a community member who created a special device type handler called “the Z wave tweaker.”
What you are going to do is temporarily assign your switch to the Z wave tweaker, then set all the associations so that you can get Control over tapping the top of the right switch, tapping the bottom of the right switch, double tapping the top of the right switch, etc.
Then once all the associations are set up, you will switch back to the regular DTH and everything should work fine.
If you haven’t worked with custom code before, start with the following FAQ (this is a clickable link) and it will explain the basic idea
To get the code for the tweaker, see the following thread:
And to find out which association groups go with which tap patterns, see the manual for the device:
If all of that sounds great but you don’t really know how to do any of it, there will be lots of people who will be happy to help you. I myself I’m not feeling very well today, so I’m just going to leave this here. But you should definitely be able to do it. :smiling_face_with_sunglasses:
