I have an AVR with two zones. The second zone has volume buttonz on the remote and in the Harmony app under device. Is there a way with webcore or other SApp to hook into that command so that I can program the volume controls without using g the Harmony app or remote?
It’s not that easy to control individual devices through your harmony hub outside the context of activities.
This is the only method I’ve heard about. You’ll need to be comfortable working with a raspberry pi.
Hello,
I made small SmartApp and DTH. If you need, just test and give me a advice.
—UPDATE—
5/16/2017 - support multiple Harmony-hub(v0.1.5.000)
5/22/2017 - added SmartPlug’s power monitoring to synchronize device state
8/30/2017 - added Harmony API server’s IP changing menu and Contact Sensor monitoring mode to synchronize device state
KuKuHarmony
KuKuHarmony is a SmartApp give users the ability to control each device by Logitech Harmony.
It works based on ‘Harmony API ’
With KuKuHarmony based on ‘Harmony API’, you can turn on and turn off devices individually.
The device’s other commands are also support.
ex) volume up/down, channel up/down, FanSpeed, Menu and so on
Features
Provide a device’s Virtual device
List Hubs
List Devices
List Commands
Turn on/off each device(no…
