Just checking to see if anyone has their Propane TankUtility Fuel Level Monitor successfully integrated with SmartThings?
By way of background:
- I have a Generac 7005 Propane Tank WiFi enabled Fuel Level Monitor - (note: seems to have been discontinued and replaced by the Generac 7009 4G/LTE version).
- An Android App called “Tank Utility” (along with it’s Companion-App called “Tank Utility Setup”) (although both are no longer available in the PlayStore; the “Tank Utility” has since been replaced by Generac Mobile Link)
- The original Web App interface of app.tankutility.com automatically forwards to app.generacfuel.com, which continues to function properly with all of my Account & Device Info intact & functional.
- @TAustin 's Edge Channel TAustin Driver Tests Subscribed
- @TAustin 's Edge Driver “Tank Utility V1” Installed
- @TAustin 's EdgeBridge Installed/Running on a Windows Desktop
- @TAustin 's EdgeBridge Monitor Installed/Running in SmartThings indicating “online”
- @TAustin 's Tank Utility Installed: but not functioning yet
The stumbling point I think is obtaining the “Personal Token” to be installed into the SmartThings/Tank Utility/Menu/Settings/Personal Token field.
I found in older posts where it used to be visible at the bottom of the TankUtility App/Reports Graph, but it’s no longer there.
So any suggestions as to how to obtain the Personal Token?
As well, can anyone confirm whether this (or another system/method) is working within SmartThings ?
