Hi
I’m trying to use a SmartSense Multi with a Telegesis Coordinator.
I can register the Multi to Coordinator PAN and I can get back Cluster and Zone information.
Unfortunately I cannot find a bit that changes when the magnet is moved. It looks like the device is currently inactive.
Is there anyone who can advise what the Cluster and Zone Bits and Bytes map too and what I should set to make the Multi transmit changes of switch states?
I’m trying to integrate an offline system. The full SmartThings platform can be programmed to do everything I need, with the exception of the offline requirement. I do not have an internet connection available in the location that this is to used.
Regards
Hugh
