I’ve got a color bulb that has been refusing to shut off for about three days. No new related automations but I did install a new Inovelli dimmer and move around a couple of GE switches this weekend (all z-wave). Every time I turn off the bulb by routine, voice or app, it pops back on a second or two later. Regardless of what it’s doing when I turn it off, it always comes back on in a soft white. Nothing is showing up on the Recently tab, just “switch is off…switch is on”. Any ideas?
I’m using the stock Zigbee RGB bulb handler, V2 hub, and mostly the classic app; my primary automations are through Smart Lighting but I had some color stuff set up through webcore. Removing this bulb from the list of authorized webcore devices hasn’t made a difference.
This is the only thread I’ve found with any similar behavior. I would have guessed the cause was similar, a backend change, but I have another of these bulbs which is behaving properly, along with several Smart+ soft white bulbs. The other color bulb was installed 5-6 months after the first so if it’s a question of runtime, there’s a big difference there.
I’ve submitted a support ticket to Sylvania and I’ll get one in to Samsung tomorrow. Anything else I’m missing?
Here’s some live logging while I turn it off:
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:42 PM: debug [raw:0104 0008 01 01 0000 00 6F83 00 00 0000 07 01 00, profileId:0104, clusterId:0008, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:6F83, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:8, commandInt:7]
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:42 PM: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 01 01 0000 00 6F83 00 00 0000 07 01 00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:42 PM: debug description is catchall: 0104 0008 01 01 0000 00 6F83 00 00 0000 07 01 00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:40 PM: debug [raw:0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 4100, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0000, messageType:00, dni:6F83, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[41, 00], clusterInt:32801, commandInt:0]
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:40 PM: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 4100
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:40 PM: debug description is catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 4100
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:38 PM: debug ON/OFF REPORTING CONFIG RESPONSE: SmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x6f83, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x07, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0000)
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:38 PM: debug description is catchall: 0104 0006 01 01 0000 00 6F83 00 00 0000 07 01 00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:36 PM: debug [raw:0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 4000, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0000, messageType:00, dni:6F83, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[40, 00], clusterInt:32801, commandInt:0]
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:36 PM: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 4000
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:36 PM: debug description is catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 4000
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:26 PM: debug Configuring Reporting and Bindings.
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:23 PM: debug [raw:0104 0008 01 01 0000 00 6F83 00 00 0000 07 01 00, profileId:0104, clusterId:0008, sourceEndpoint:01, destinationEndpoint:01, options:0000, messageType:00, dni:6F83, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00], clusterInt:8, commandInt:7]
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:23 PM: info DID NOT PARSE MESSAGE for description : catchall: 0104 0008 01 01 0000 00 6F83 00 00 0000 07 01 00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:23 PM: debug description is catchall: 0104 0008 01 01 0000 00 6F83 00 00 0000 07 01 00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:21 PM: debug [raw:0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 3D00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0000, messageType:00, dni:6F83, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[3D, 00], clusterInt:32801, commandInt:0]
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:21 PM: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 3D00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:21 PM: debug description is catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 3D00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:19 PM: debug ON/OFF REPORTING CONFIG RESPONSE: SmartShield(text: null, manufacturerId: 0x0000, direction: 0x01, data: [0x00], number: null, isManufacturerSpecific: false, messageType: 0x00, senderShortId: 0x6f83, isClusterSpecific: false, sourceEndpoint: 0x01, profileId: 0x0104, command: 0x07, clusterId: 0x0006, destinationEndpoint: 0x01, options: 0x0000)
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:19 PM: debug description is catchall: 0104 0006 01 01 0000 00 6F83 00 00 0000 07 01 00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:17 PM: debug [raw:0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 3C00, profileId:0000, clusterId:8021, sourceEndpoint:00, destinationEndpoint:00, options:0000, messageType:00, dni:6F83, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[3C, 00], clusterInt:32801, commandInt:0]
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:17 PM: info DID NOT PARSE MESSAGE for description : catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 3C00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:17 PM: debug description is catchall: 0000 8021 00 00 0000 00 6F83 00 00 0000 00 00 3C00
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:05:07 PM: debug Configuring Reporting and Bindings
Here’s some adjacent entries that ST isn’t associating with the device label but which mention it by name:
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:07 PM: info postEventToEndpoint: event successfully posted.
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:07 PM: debug doesTvSupportVoice SYLVANIA Smart A19 RGBW: false
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:07 PM: debug Property Changed event switch: on (source: DEVICE)
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:07 PM: debug routeEndpointEvent event name: switch, physical?: false
0a1d6681-c6a5-4f00-bb30-78d199249ff5 9:08:07 PM: debug Configuring Reporting and Bindings.
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:05 PM: info postEventToEndpoint: event successfully posted.
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:05 PM: debug doesTvSupportVoice SYLVANIA Smart A19 RGBW: false
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:05 PM: debug Property Changed event switch: off (source: DEVICE)
1a6107f7-e92c-447f-9c0c-4264f4ee557d 9:08:05 PM: debug routeEndpointEvent event name: switch, physical?: false
