Switchbot - Simple “power on” for some TVs (IR blaster)
@djh_wolf The Switchbot hub control through Actiontiles can be a bit slow due to it not being locally executed, but it is fast enough for me.
I placed my switchbot mini hub under my TV to control on/off, and then have a simple USB powered IR extender that sits next to the switchbot hub that relays any command down to the basement theater rack.
My TV is only connected to a PC so I only need it on/off. The IR extender controls my Receiver power, volume and input.
As you can see from my post 14 above, I have added created an actiontile panel for TV watching.
EDIT: If you are interested in controlling smartthings devices from a PC or the other way around, search eventghost. http://www.eventghost.net/
I use it to create keyboard shortcuts to control the PC as well as Smartthing devices, like lighting, and even the switchbot hub.
