Switchbot Leak sensor problems
I’ve bought the New Switchbot Water leak sensor. I already had switchbot to smartthings connected, so when Connecting the sensor to smartthings it automaticly showed up.
The Problem is, since that the sensor Just says “connected” in the smartthings app and when I click on the device There is an error message.
In the switchbot app it works Just fine.
What can I do about it?
Hi, @PalBeron
I can take a look to see if there was something wrong on our side or Switchbot’s.
Can you enable support access to your account, please?
  2. Enable support access to your account
Also, do you remember the approximate time when you installed the device? This is to look for the log of the event they sent to add it to ST. If so, please include your timezone.
Hi @nayelyz ,
Thank you for your Response.
I enabled the Support access. Yes it is the same Email adress.
I don’t know which time I intially connected it, but it was the 22. of Aug.
Hi @PalBeron ,
Thank you for enabling support access and confirming your email address.
Could you please try reinstalling the sensor and then send us the recent logs? We need the exact timestamps to analyze the issue further.
Looking forward to your response.
Is deleting the sensor and reload the integration enough?
@PalBeron Yeah, but please do not forget to send the logs after that, without closing the app.
Should be done since between 21:02 and 21:04 cest
@PalBeron ok we are waiting for logs to confirm and review. It may take a few minutes
Hello @PalBeron,
We haven’t received your logs yet. Could you please follow these steps for your iPhone to send them to us?
First:
  1. Enable the creation of additional logs in the app:
  • In the SmartThings app, go to Menu > Settings.
  • Scroll to the bottom of the page and find the section called Troubleshooting. Please enable the option that says Create Additional SmartThings Log.
  • Restart the app.
Then:
  1. In the app menu, go to Contact us.
  2. Tap on Error reports.
  3. On the opened page, tap 10 times on the title/label “What is the error about?” or until the prompt to create a log appears.
  4. Click on OK and wait for the process to finish. Save the generated file in your preferred location and share it with us at build@smartthings.com.
Thank you for your cooperation!
I’ve sent it
Great! I’ve seen them, thanks once we have an update I will reply you on this post.
Hi @PalBeron,
Thank you for sending us the logs! Our team has reviewed the information, and we have identified the issue regarding the SwitchBot Leak Sensor reporting only its healthCheck capability in the SmartThings app.
I’m happy to inform you that this problem has been resolved. The device should now display all of its capabilities correctly in the SmartThings app. Please reinstall the device one more time and verify its status. Let us know if you encounter any further issues.
Thanks again for your cooperation, and feel free to reach out if you need any more assistance.
