Hello community, I had looked up this issue I’m having and not found anyone else who’s having it. I have the switchbot integration with smartthings, with it I have connected the switchbot temperature/humidity sensor and a Bot.
The issue I’m having is that every 12 hours the Bot turn on by itself. It seems to be related to refresh interval of the switchbot cloud to smartthings, I believe this because before I installed a smartapp to pull out information from the temperature/humidity sensor every 5 minutes, the sensor only updated the information every 12 hours also, at the same hours the bot is turning itself on (6pm and 12am).
Otherwise, you’ll just have to start looking for automations that might be doing it, including in the switchbot app and your smart speaker app if you have one of those.
Thank for the reply Roberts. I checked the Alexa hunches and it wasn’t it. I have an automation in ST that turn off the Bot 5 seconds after I turned on to keep it always off ready for the other ST scene where I use it.
Is there any way of checking if other ST automation or scene is triggering the bot? I have a good number of those and that I know, only use the bot in the two I mentioned. The odd thing is that turns on at the same time every day, 6pm and 12am, and I’m sure that I don’t have time triggering routines.
Also don’t have any routines on the switchbot app.
