Switch Questions
[quote=“davidacollins, post:1, topic:38670”]
If I were to add the in the wall switch to a standard light switch, how controllable is switch? If a standard toggle switch is set to “off” can the controller then control the switch through the app? [/quote]
If you are talking about the Aeon microswitch, then it’s fully remote controllable (but it requires a Neutral wire). It also has strobe and flash capability, and in addition to working with conventional toggles, can also be used with a momentary button or their touch-screen switch.
http://www.amazon.com/Aeon-Labs-DSC26103-ZWUS-In-Wall-Controller/dp/B008VWBNAU
Usually, but it depends on the smartapp you use to control it. If you use Rule Machine, you can pretty much do whatever you want.
