I have some development experience, so I thought I might try my hand at creating an Edge driver for a Linear WT00Z-1 that I’ve been using as a scene setter for years. I have the new driver installed.
Though I’m dumb as a box of hammers, I do like puzzles: can anyone point me in the right direction? What’s likely wrong in my source file?
- With logcat, I can see the up and down “events” (with different payloads for on and off).
- When I control the switch (on/off) from the app, the switch “capability-status” updates on/off. However when I tap the physical switch, “capability-status” does not update.
- FWIW, (re)installing the driver also causes the status to update to current state.
I’ve already tried to remove/add the switch device, power-cycled the switch, etc.
Here are the events emitted when the switch is physically pushed:
ON (pushed up)
2023-01-15T01:38:45.563187175+00:00 TRACE Linear Z-Wave Switch Received event with handler unnamed
2023-01-15T01:38:45.567984359+00:00 INFO Linear Z-Wave Switch <ZwaveDevice: ... [14] (Linear WT00Z-1 Switch)> received Z-Wave command: {args={value=255}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="NONE", payload="\xFF", src_channel=0, version=1}
2023-01-15T01:38:45.663126764+00:00 DEBUG Linear Z-Wave Switch Linear WT00Z-1 Switch device thread event handled
OFF (pushed down)
2023-01-15T01:39:20.348425881+00:00 TRACE Linear Z-Wave Switch Received event with handler unnamed
2023-01-15T01:39:20.352485090+00:00 INFO Linear Z-Wave Switch <ZwaveDevice: ... [14] (Linear WT00Z-1 Switch)> received Z-Wave command: {args={value=0}, cmd_class="BASIC", cmd_id="SET", dst_channels={}, encap="NONE", payload="\x00", src_channel=0, version=1}
2023-01-15T01:39:20.357853673+00:00 DEBUG Linear Z-Wave Switch Linear WT00Z-1 Switch device thread event handled
Thanks for any help…
