Sunset trigger
Hi, anyone has used the sunset trigger recently with SmartThings app automation? it doesn’t trigger at all for me and I have checked the location permission is always on
I have lights at 2 locations that turn on based on Sunset with offsets. They seem to be working as expected. I am in the northeast US.
I use sunset triggers with no problems but its through routines.
Has it worked previously but stopped recently, or have you never had it work?
Can you confirm you have set the geolocation for your SmartThings Location?
No problems using sunset triggers (with offsets) here on multiple routines.
yes, I do have geolocation turned on with my phone.
Thanks for the feedbacks, sounds like it works for everyone so I will keep investigating.
Do you have a SmartThings hub? I believe the sunset trigger uses the location of the hub, not your phone.
@JDRoberts can probably shed light on this.
It uses the geolocation set in your SmartThings Location (in the app use Home > Three-dot menu > Location Settings > Geolocation).
The AWA is a good place to quickly check it is set.
