Just upgraded to the new app and set up some new automation based on sunrise and sunset. I noticed that none of my automation that uses the sunset as the trigger worked. I have automation for the outside lights to someone 30 minutes before sunset. Looking at light history, this automation doesn’t seem to be triggering. Similarly, I have another automation to turn off a plant light at sunset, also didn’t run today. Any ideas>?
Install the smart lighting smartapp and create a rule that uses sunrise or sunset to see if that fixes sunset/sunrise in your automations. Also check that your geolocation is set correctly in the new app —> 3 dots in the upper right of the screen and select Manage location and click on geolocation.
