Suggested Improvement to Reboot "Offline" Hubs that are inaccessible
Matt -
Does not work reliably. Support is regurgitating from a FAQ.
This does not work for most hubs even when they are in a perfectly health state - eg you can click that link all you want and it still won’t reboot. That says nothing for a degraded state where the hub needs rebooting due to some issue, there is no saying this type of remote command would work - even if they solved the issue with the utility not working at all.
ya wasn’t sure… just happen to read that post right after yours. If the hub can’t communicate then for sure not going to work. And the fact that it doesn’t really work anyway is awesome.
So we have a vacation home. Haven’t put ST there yet. However currently I have my cable modem reboot once a week due to the crap Internet provider. I am going to put ST there, when I do I will put it on a switched outlet that I can hit without ST. I will also not have batteries, as I use a UPS for everything now… Powers camera’s and current motion stuff for about 5 hours.
Having spent 20 years in IT I am a firm believer in having other ways in. I do completely agree with the comments about having a watchdog service. Self healing hardware/software is the essence of risk mitigation.
And here I am again with an offline hub that needs to be rebooted, but can’t be - because I am not home.
SmartThings - your V2 hub battery backup is awesome - except that the hub just never seems to retry/reboot/reset networking. Like ever. If it goes offline it just never tries to reconnect.
Guess it will work again when I get home. Maybe I can build a robot that can press the reset button and I can remote control that? Yes… that could work.
Yes, same here. I’m about ready to give up on ST just for this reason. It’s useless when you travel unless you have someone that can go in your home and restart it. A solution was offered on here by and engineer that made a lot of sense to me. Why they wouldn’t do it is a mystery to me.
edimax wemo or neo wifi switches… also ups and remove batteries
Got home. Pressed reset button. Rebooted - no work. Pulled batteries and AC, put em back, rebooted. No work. Went into Web IDE and pinged hub… finally worked again.
Seriously, the loss of connectivity recovery is REALLY BAD. REALLY REALLY.
Anyway, yay my home works again.
I’m on the fence about returning to my Vera controller due to my V2’s inability to properly recover from network outages. While I watch to see whether or not Smartthings can address such a major availability problem I’ve re-installed my Vera3 to control the power to my Smartthings V2 hub. I also removed the batteries from the V2. So far so good but sooooo frustrating to have to build such a workaround.
I can reliably make my v2 hub go offline and remain offline by simply rebooting my router. That’s not ideal (as they say) - I wonder if there isn’t any network recovery code in the hub.
Can anyone else test that? I’ve got an Asus router which is connected to a cable modem and it’s providing DHCP addresses on the lan side - when I reboot it, ST reports fairly quickly that the hub is offline, and it stays in that state until I reset the hub. Then hey presto it’s back online. It’s as if the hub just doesn’t even try to reconnect when it loses network connection.
I have restarted my router all the time, without issue.
That being said, my HUB is connected to a switch, and not directly in the router.
Same here. No issues.
I’ve got a v2 hub that must be physically reset every time my AT&T Uverse router (to which it’s connected) has a hiccup…and starting about two weeks ago, it’s been fairly common. And definitely a pain in the rear.
Today I’m moving the ST hub over to a gigabit switch. I don’t know why I chose to connect the hub directly to the router to begin with…maybe that was the recommended setup? I don’t remember.
We’ll see if that helps…
…and this morning, the AT&T Uverse box (3801HGV) had another brief outage, and the ST Hub v2 doesn’t like that. Connecting the Hub to a switch instead of the router didn’t help. Again I have to unplug, remove batteries, wait a bit, and then reassemble.
This Hub will crash upon any internet connection interruption. Is this really typical operation?
Same issue here. I’ve had the Hub v2 for over a month now and this is the 5th time the hub goes offline and never connects until I disconnect power, remove batteries etc.
I don’t remember having this problem with the v1 hub…
Is the solution really to connect the hub to a switch instead of directly to the router??
Wondering if maybe you guys have a defective hub or bad internet connection.
I have had my hub for about a month too and no issues at all with it going offline.
It didn’t work for me. I’ve tried both ways…same issue.
same here I have a switch on my hub and wifi and rebooting either is fine…
How did you set up the reboot for the hub to occur say every three days? Thanjs
Continuing the discussion from Hub Firmware Release Scheduled for 4/21/16 (Hub V2) - 14.38:
Verified this is fixed for me with the firmware update on 4/21 :slight_smile: Comcast outage… cleared up. Boom, hub came back online with no intervention from me. Yay!
A reboot of my router will cause my ST hub to go offline indefinitely until I physically reset it. But it’s only been occuring the last few weeks or so. My router has always rebooted Tuesday at 3:30 AM, and only with the previous update has this been an issue. I did contact support, but haven’t heard anything back yet.
And it’s still an issue. I had it occur this morning.
