Suggest a Device
http://www.amazon.com/Wireless-Universal-Anywhere-Automations-Management/dp/B00V5WAEDA/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1433449639&sr=1-1-catcorr&keywords=geeklink
All i’m picturing is a way to finally control my Hunter fans (433mhz) if smart-things can integrate with it.
SmartThings IFTTT channel gives you a lot of options as long as you’re OK with a potential 15 minute polling delay. Which might be fine for fans.
@Ben We need something like an alarm panel/control center for people that are not tech-savy, something like the wink relay but better and made by smartthings, this would make the system A LOT easier for the end user, i dont want to install a system that depends on having a technician on the house to control/program/teach the system
Thanks for asking. Here’s my 2c for device suggestions:
I’d love to see more camera options: Foscam integration would be amazing. Blink too, once it’s released. Dropcam is $$$. Along with the camera management, Dropbox or Amazon Cloud integration to save camera photos would be great, plus ability to email / push alert a camera snapshot when an event happens (e.g. when a door opens).
Add multi-Sonos integration, so several units can be controlled at once.
Lastly, some kind of door chime / door “chirp” when doors open (would likely require a new device). I tried to do this with Aeotec Siren but discovered the Siren can’t function in chirp mode - it’s an all-or-nothing siren. I’m hacking this with Sonos at the moment with a “door open” alert - but have found that the alert doesn’t always play (seems like the Sonos has to “wake up”).
I know it’s been talked about quite a bit, but official support via Amazon Echo would be awesome, hopefully not too long from now since SDK is released and is officially supporting WeMo and Hue.
Chamberlain MYQ
Honeywell Redlink/Wifi Thermostat
Rachio Sprinkler
Ring Doorbell
I would like to know that the Trane TCONT624A thermostat will connect as a SmartThing. Thanks, Rita
Looks like a nice device! It will likely connect to Smartthings as a basic zwave thermostat, but it has a number of nonstandard features, including wireless firmware updates, that will probably only work with a Nexia controller.
Is there a recommended thermostat to use with SmartThings? I suspected what you have confirmed. I will try without Nexia but may have to replace the thermostat to get best use of the device. Thanks, Rita
I’ve started a new linked topic for you so you can get detailed recommendations.
How about the Smartenit Wireless Ball Valve controller - ZBVC-1?
For the toilet monitor - so I used the SmartThings moisture sensor (which looks exactly like the PEQ sensor.). It works great,but the battery only lasted 3 days (makes sense because it is normally shorted, but I cannot believe you change it every 3 days for the coffee pot)
You’re right. I definitely do not change the battery every three days. I’ve still got the original battery in it and it is still at 66%. The water sensor is generally tripped for about 8-10 hours a day so I would imagine mine would have died by now given your results. Have you tried clipping/unsoldering the LED to prevent that additional battery drain?
That was one of the things that I was wondering if you did. I do like the LED (at least for testing), but if its gotta go, then its gotta go. Maybe adding a resistor might help too although the less mods the better. I also wonder if the # of flushes (across entire family) -> which means increase number of broadcast is the difference? You probably have 1 wet- 1 dry per day. I show 58 (29 flushes) transitions in 48 hours.
The change is being reported. The more changes, the more reports, the higher the daily power draw.
I never removed the LED from my sensor but I fully intended on doing it until I realized that my battery wasn’t draining as fast as I thought it would. Like @JDRoberts said, I think it may be due to the number of state changes.
Side note - 29 flushes seems crazy high! Do you happen to have a cat named Jinxy?
Taskr would be amazing!
That is one thing I like about data… it reveals stuff you never would have thought of before. At first thought, 29 seems high, but for 4 people over 2 days, that is less than 4 per day and I can do 4 an hour when drinking coffee or beer (or Tequila)
We track people’s motion at a facility and when I was new, I noticed that nobody was moving (~10 patients, 4 nurses) in like 10 minutes. It was a holiday but I drove all the way to the facility to see why it wasn’t working. Guess what I found ? Nobody was moving. Even on a workday, people just don’t move that much.
Another one that is REALLY high is how many times people open the refrigerator in a day.
Would love to see Halo Smartlabs smoke detectors get integrated. They are really cool with notifications for smoke and carbon monoxide as well as weather alerts. Does not appear to be z-wave or zigbee but is wifi so maybe hub v2?
I would like to see Aeon Labs Aeotec Z-Wave LED Light Bulb, Gen5 as an officially supported device.
