All, I am hoping someone can help.
I have the latest smarthings hub, serial # 000.024.00022 connected to 3 STZW402+ thermostats on zwave. And I have the latest app on iOS.
After a few months of normal use I have been seeing a consistent problem.
If I set the temperature to say 17 degrees C with the room temp higher than 17 the thermostats will still switch between heating and idle every few seconds (even though the heatingSetpoint is set to 17), leading to an overheated room, as high as 19 degrees C. It also heats with 4 bars on the thermostat display.
If I reset the thermostats manually, 1 at a time, and reconnect them to the Hub the thermostats will work correctly again, with 1 bar of heating when the room temp is close to the thermostat temp. As soon as a thermostat reaches the desired temp it switches to on the zero bars display and Idle on the app. Later on, after some temp adjustments on the app, the thermostats will eventually start to overheat the room.
Why would all 3 thermostats keep heating when the room temp exceeds the thermostat setting?
This is from the logs when room temp is 18.5 degrees and the thermostat set to 17 degrees:
1:57:48 PM: debug Parse returned [[name:thermostatOperatingState, value:heating, isStateChange:true, displayed:true, linkText:Living Room Thermostat, descriptionText:Living Room Thermostat thermostat operating state is heating]]
1:57:39 PM: debug Parse returned [[name:thermostatOperatingState, value:idle, isStateChange:true, displayed:true, linkText:Living Room Thermostat, descriptionText:Living Room Thermostat thermostat operating state is idle]]
1:57:32 PM: debug Parse returned [[name:thermostatOperatingState, value:heating, isStateChange:true, displayed:true, linkText:Living Room Thermostat, descriptionText:Living Room Thermostat thermostat operating state is heating]]
1:57:22 PM: debug Parse returned [[name:thermostatOperatingState, value:idle, isStateChange:true, displayed:true, linkText:Living Room Thermostat, descriptionText:Living Room Thermostat thermostat operating state is idle]]
